long crank, hard start after hot soak
1967 442
400 CI
symptoms:
after a hot soak, the engine cranks a long time before starting. i find pumping the gas 5 or 6 times helps but this isnt normal.
during hot soak, fuel seems to be draining back to the tank. the draining back lasts about 5 minutes.
check out the video:
http://www.youtube.com/watch?v=9Q2YbLAdcoY
has anyone else seen this phenomenon ?
400 CI
symptoms:
Get rid of the glass filter they are prone to leaking and/or breaking and go to a all metal fuel filter unless you want a fried Olds which is not a pretty site. I have seen this in more then one instance.
