455 efi conversion
455 efi conversion
started with some tech drawings
measured fuel rail drill points
drilled fuel rail pilots
set up intake on drill
all drilled out
epoxying the bungs in
grind and re-epoxy underside
checking to see if i have room with a 2 inch spacer
tapped up for paint
por 15 black sprayed
por15 engine enamel aluminium
all drilled out
tapped up for paint
old 455 bored 30 over 9.5to 1 compression. forged rods and pistons. all the casting numbers were ground down on the heads so I have no idea what they are. nodular crank. gotta get cam specs. port matched intake and heads. magnum rockers, jomar stud gurdle headman headers.
its going in my 78 trans am
Do you have to run the spacer so the linkage clears the rails?
Have where does the tip of the injector sit in the runner.If it is up inside the bung,you need to move it down.Otherwise it will spray the barrel of the bung,then drip down into the runner.You want the tip of the injector to be flush with the roof of the runner.Looks great so far.
since i angled the injectors the bottom of the o-ring sits right up against the manifold.
i will br running a megasquirt to control fuel and timing
Having installed a few of these over the years may I recommend having someone do the tuning for you. It is a real PITA and it doesn't take much in the wrong direction to damage the engine.
got the valve covers on
got fuel rail mounted
got injectors wired and pcv run
i wish there was a local tuner that was familiar with ms
That is BA! Is the EFI a fuel mileage thing or a power thing or both? It seems like a lot of work but it is definitely going to be one-off! Looks really good! I love the valve covers, wish I could spend the money on some like that...chrome will do for now.
Wow, i may be a little slow on the draw here but thats some amazing work you've done
Ive seen a few EFI Olds 350s running around but its pretty rare to see a 455 with it, its something ive been wanting to do with my rebuild. Ive always wondered how good i could get mileage while still pulling monster big block torque xD ive heard of people on here pulling 15mpg in the city on built 455s, thats getting dangerously close to my 3rd gen camaro's dinky smogged TBI 305 0_0 hell id do that swap any day haha
This is me
http://www.youtube.com/watch?v=RnSi6FgMXjE
Let me know if I can help. But I have to say I'm not a real MS fan.
This is me
i would love to do an accell kit but i just dont have the $2000-$3000
the only way i could do it is if they sponsored my car
but i don't know if they do that
Based on the fact that you pretty much have everything else all the elctronics are $1850.00 with a wideband. That's ECM with a base tune, harness, and the wideband as mentioned. Imo head and shoulders above the MS.
Great build
Hessdawg, What a NICE Build. I run Megasquirt on my 76 BMW and I'll be going full sequential spark and fuel with it. I also have a 62 Olds 88 with a 394.
Couple of questions, what did you do for spark control on this engine?
I'm new to olds, so trying to figure out my options for crank pulley/pickup arrangements. I probably will end up having to have something made up.
how did you manage fuel? In my BMW I was able to use a high pressure in-tank pump that fit from another model, so it was easy..
Cheers!
Cheers!
Cheers!
i am running an ms2 right now and an edis8 for the ignition as you can see in this pic lin the lower right by the crank pulley i have a 6.75 inch 36-1 wheel and a ford crank sensor
heres a closer shot
you can see in this picture the cop set up
and this is what my edis wiring looks like so far
i also converted the distributor over to a cam sensor so in the future i can run full sequential. but i do have i question for you on the cam sensor? should the single tooth be pointed at the pickup with the engine at tdc 1???
Wow! You basically just answered my question and that's what I plan on doing for ol beulah. (62 dynamic 88).
Yep, on my BMW the sensor is triggered at TDC 1. I drilled the upper timing chain cover and stuck a sensor in there. you want to be sure there isn't much room for play and those bosch distributors and the gear arrangement bmw uses on those cars flops around a bit. Your setup looks sound though.
Thanks for the info, and the wiring. That'll get me on my way to figuring out my install.
Yep, on my BMW the sensor is triggered at TDC 1. I drilled the upper timing chain cover and stuck a sensor in there. you want to be sure there isn't much room for play and those bosch distributors and the gear arrangement bmw uses on those cars flops around a bit. Your setup looks sound though. If you're talking about the sensor for injector timing that won't make a bit of difference.
#31
Yeah I'm not 100% sure the edis will work the way it's wired but fingers are crossed. The motor is back out on a stand and the old Holley 4d is back on to breaking the new motor. Cause it was pre programmed before the motor was rebuilt
Hoping to start it next week
I'll try and post a video
#32
Obviously a pre-built unit is easier, but i'm thinking feature set.
Also regarding your comment to cam tdc timing signal. I thought those had to be pretty static, when I designed mine, I followed what I saw on other newer cars, usually something coming off the cam, and non-adustable. Flutter from a distributor gear won't be an issue? That's good to know, as I know some people in the BMW crowd find it easier.
Cheers!
#33
#35
I'm not trying to be contrary, but I am curious, in what ways?
Cheers!
Cheers!
You normally change injector timing in 30 degree intervals, so a sensor that varies a few degrees here and there isn't critical like it is for ignition.
Hope this helps.
#36
Download the software of each and compare. If you're only going to run in a straightline then the MS is fine. If you want the best driving vehicle you can get in this price range then the Accel is far and away better. Why? Simple, because for one it has twice the transient fueling tables the MS does. There are other things that set it apart as well.
Hope this helps.
Hope this helps.
I'll download the software and take a look. And thanks for the explanation, that helps quite a bit.
