68 delta 88 455 with a C head and a E head
Old August 16th, 2011, 05:44 PM
CLcutlass's Avatar
I brought a 455 out of a delta 88 and it has 1 c head and 1 e head. Can I use this combination. The guy who I brought this from did drive it as a daily driver but is this a good performance combination.
CLcutlass is offline
Old August 16th, 2011, 06:33 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Yeah, enjoy.. C head is 1969, and the E head is 1970. Not much difference in performance.
J-(Chicago) is offline
Old August 16th, 2011, 06:45 PM
ah64pilot's Avatar
I don't think a mismatch is going to be a great way to achieve stellar performance. But I believe if you stick with the cam you were talking about running in the other thread you won't notice a difference.
ah64pilot is offline
Old August 17th, 2011, 03:39 AM
CLcutlass's Avatar
thanks ....thats my intention now
Old August 17th, 2011, 09:10 AM
The differences in the two castings are negligible. The big difference is valve size - are both big or small valve?
joe_padavano is offline
Old August 17th, 2011, 09:51 PM
2blu442's Avatar
Joe, way back when I bought my 1970 442 as a basket case it had one C and one E head. Its been a lot of years now, but I thought the spring height was different between the two heads. Could that be true... or just cobwebs in my memory? John
2blu442 is offline
Old August 18th, 2011, 12:38 AM
John, you are correct.
The C heads do not have rotating keepers (68-69)
The E heads have rotating keepers on both intake and exhaust valves. But their spring pockets are the same depth I believe (70')
The G heads have one spring pocket taller than the other if I remember correctly, and only the exhaust valve rotates. (71')
The (72') Ga heads have the rotators on both intake and exhaust again and the pockets are equal again I think. Be careful here because they may have the same casting number, but not be the same.
Someone please correct me if I am mistaken on any of this.....kinda skimming off the top of my brain right now.
Here's a pic of the e head from another thread.
And.... the C head.
Also,take a hard look at these #7 heads from 1971. It's easy to see the staggered valve spring pockets by looking at the valve guide bosses.
Old August 21st, 2011, 06:25 PM
CLcutlass's Avatar
thanks for the info...I am not sure of the valve sizes as I do not have the heads off yet.
young olds
June 3rd, 2014 08:13 PM
Olds Scott
May 29th, 2013 08:15 PM
Ragtopw1972
October 18th, 2012 08:19 AM
72 Olds Project
May 6th, 2011 04:01 AM
Blownolds
July 17th, 2010 04:01 PM
Quick Reply: 68 delta 88 455 with a C head and a E head
