What fan should I use?
Just overheated waiting in line to register at a local show. A previous owner put a flex fan on this 455 in a 71 cutlass. I think this is my problem. What is the proper or best fan for me to change to? By the way outside temp was 100 degrees when this hapened.
You mean you hear a constant roaring sound even when it is running cool? If so, the clutch (if equipped) may not be disengaging. Provide us with some more info (year, model, A/C or not, when you hear it and not) so we can help..
Normally it should engage for a few minutes after a cold startup but after then should disengage. It should then engage again when the temp. in front of it exceeds 195* and disengage when it drops below that.
A five, six, or seven blade fan with well operating clutch is probably best. If you want to try a good flex fan, they were OEM on some Buicks, etc. They are much different from the aftermarket junk that cools about as well as having nothing on the hub. I have several Buick type fans that I have been hoarding for 30+ years and will never use. I'd sell them for not much more than shipping, but that could be expensive these days.
Converting to electric fans will not always show a benefit.I coneverted to twin pullers for no reason.I just felt like doing it. My previous set-up was a factory Harrison radiator,with factory shroud,and a $15.00 Flex-a-lite nylon 6-blade fixed(no clutch)fan.I NEVER had any issues with this set-up,no matter what I was doing with the car.Even on the hottest/humid days,it never got above 185*,even sitting in city traffic or a parade.
A few years back I decided to swap the radiator for an aluminum Griffin,& install twin Flex-a-lite pullers.It runs exactly the same,185*. I didn't shed any weight either.What I lost in radiator weight,I gained back with the electric fan assembly.
Not a lot to gain on a street car going electric.
I already had the better alternator on the car anyway.I literally had these parts laying on a shelf in my garage,and I had some free time one afternoon,so I swapped it all over.It's the only way to find out.My ET's weren't any different either.I plan on running an electric water pump on my 517 when it's done,so the fans & radiator will stay the way they are.I just know I don't need to go out of my way to do this on another car.
so the fan I have is a running fan, no matter hot and cold... what I want to know is how does the clutch fan work? how does it know to kick in... and where do I get one? few tid bits about installation would be great! thx
With the electric fan and pump, my mph increased 1.1 and my e.t. dropped .09 - and I could cool the motor in under 5 minutes between runs, and the motor ran cooler all around (but MUCH more cooler in low-speed and stop-and-go traffic).
Lee
The clutch monitors air temperature off the radiator with both an aluminum finned body and a bimetallic spring (like a thermostat). If below 150* it kinda freewheels. Between 150-190*, it will engage via fluid coupling, having no more than 25% slippage. The result is a large volume of air being moved until the temp drops enough for the clutch disengages. The clutches can be found at most auto parts stores. Installation is based on your year and model car and if it came with a clutch, has A/C, etc.
JpMotorsports
May 15th, 2014 07:08 AM
davesdelta
Body work
October 14th, 2009 12:03 PM
ninob7979
April 7th, 2009 07:19 AM
327supreme
February 15th, 2009 05:45 PM
