455 engine build
455 engine build
I have a 72 455 with GA heads that i'm planning on building. I'm going to use the stock heads going to do a valve job on them no porting at this time. planning on boring 30 over and using L2323 forged pistons on stock recondition rods,stock crank ,will balance the assembly put a eb proformance manifold with QJet carb (750 or 850?). I'm looking for some help on a cam, would like some lump in the cam so what would be my best bet. Looking at rear gears between 3:55 to 3:90
Auto tranny
67 cutlass wagon
Header?
stall convertor?
Roller rockers or stock?
Charlie
Auto tranny
67 cutlass wagon
Header?
stall convertor?
Charlie
Auto tranny
67 cutlass wagon
Header? I recommend them if possible, but your call
stall convertor? Again your call, depending on the size of the cam
Roller rockers or stock? What do you want to do?
Charlie
Auto tranny
67 cutlass wagon
Charlie
Jmo.
wildwillie1981
April 24th, 2013 04:19 PM
