"66 425 cracked head what do I do?
I have a "66 Olds Dynamic 88. Last week had white smoke from tailpipe so towed it to my machanic. What ever happened caused problem with radiator because of backpressure from engine in it and blew hoses (replaced radiator). Had heads tested and passenger side head is badly cracked. I'm not a mechanic so just want to know what we should do next so I don't get sold a bill of goods. Ignorance is expensive in this world. Thanks guys
Agree. Unless the crack is visible externally, it could be a bad gasket with the same symptom. If you have faith in your mechanic I would allow teardown and inspection only to see if a head is cracked or not. Have him call you when its apart to see for yourself. I would have no problem allowing my customer to come down and see what we found after teardown.
OK, first of all as the other guys suggested did your mechanic remove the heads to test them? If one is cracked you can replace that one with a used head. Or take this time to rebuild a pair of heads to install if the engine has low miles and is still tight. OR take this time to rebuild the engine replacing the cracked head in the process. I think it depends on how long you plan to keep your car, how much you use it, and if you have the extra funds to go through the motor or not. John
Thanks guys for the feedback. They had a good local shop magnaflux the heads and the one had a bad crack (i saw the result) ...so got a good replacement and resurface the other. Shop be ready in a couple of days
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
KRICHEN922
December 5th, 2009 09:39 AM
