Where is a good vacuum source?
The vacuum gauge needs to be connected to a manifold vacuum source. One of the vacuum taps on the intake is your best choice. It's OK to use a tee if needed.
Yeah, but you'll need a reducer to get down to the diameter of the hose on the gauge. It's usually easier to tee into the line for the vacuum modulator if the car has an AT. Also, most carbs have a manifold vacuum port on them.
Found it...now what?
Thank-you for the tip Mr. Padavano and Pcard! Found a spot on the intake near the carb. Reading about 18in with a steady vibration up and down between 17 and 19. Could this be caused by the exhaust leak I have at the header gasket? Thanks!
