C heads differences...?
Hi.. ,
i īm in search of a pair of C heads for my 72 455 engine,and i have a few rookie questions.
Is there any differences between the C heads,what must i know.?
How much are they worth?
many thanks
many thanks
There were also differences in the heat cross over ports. I have a set of C heads with small cross over ports that are about 5/8" wide by 1 1/4" tall. This is much smaller than the heat cross over ports on another set of C heads I have. Why the difference and was it model specific?
My location is Germany ;-(
About the valves in the Cīs:
Intake can be 2.000, or 2.072"
Exhaust are the same 1.625" correct?
About my 72 Ga :
any way to see what valve size are installed without remove the heads and measure it?
thanks
About my 72 Ga :
thanks
Brian,correct me if i am wrong...my English is not the best.
You say,i donīt feel any significant difference in Performance between the big valves Cīs and the big valves Gaīs (the Cīs not worth the extra money)?
thanks
thanks
Lady72nRob71
December 14th, 2008 04:51 PM
