Z bar stud bracket for blocks w/o the mounting hole?
So i'm trying to absorb as much info as i can for my upcoming 455 build.
Block is a 1976 FA block.
read a post mentioning that some of these blocks did not have the z-bar stud hole... I have a manual trans car, so immediately went out to the garage to look at my new block and sure enough- its not there, the pad isn't even there.
Is there a bracket or something to mount a z-bar stud on these blocks w/o the provision cast on them, or am i SOL...
Thanks-
Ben
Thanks-
Ben
Found this...
http://sdparts.com/details/scoggin-d...ts-center/sdcb
A relocation bracket for gen V & Gen VI 454's that sometimes did not have the zbar stud either... Appears to use the bellhousing flange bolts to mount to.
I know the BOP bellhousing is different from the chevys... Anyone know if those lower holes would be the same? Would be cool if i could just buy a bracket instead of having to fab one up...
Found this...
Chevy:
BOP:
I was at an Olds event 2yrs ago,and there was a guy selling a few 455's.One of them was a smogger 455 without the stud hole,with the brackets & the ball stud still attached.It was really goofy looking,but it was original.I have no idea who that was,or how often you could find stuff like that.
Only took me 3 years...
This is my first attempt at the bracket.
While templating, i quickly discovered that the "Chevy" bracket i mentioned 3 years ago, wouldn't work- Because the olds has the starter on the drivers side- the bottom casting flares out another 1/4-1/2" so the bottom hole on that bracket wouldn't work afterall.
I had to pull my 330 and bellhousing out of the car in order to mock this up properly- After I tacked it up on 330, i took it over to a friends house who has a 1966 400 block (which has the hole & pad) on a stand and test fitted it on his to check alignment of the stud hole and discovered that the big casting pad on the 330 is in a different place on the big block- That big pad was tight against my bracket on the 330, but no-where near the bracket on the 400. Wild.
A friend of mine is going to turn down the shoulder on the ballstud so we can shorten it 1/2" to account for the bracket & gap from the block and then weld it to the plate.
anyway- thought this might be of interest.
RPMRestoAndCustom
April 10th, 2012 12:40 PM
oldzy
December 19th, 2011 06:43 AM
