Ping under WOT
Old September 14th, 2010, 10:00 AM
wolskara's Avatar
Question Ping under WOT
Hey all,
I just removed the points and installed a MSD Blaster 2 coil and Pertronix ignitor (Lobe sensor) in my '69 Ninety-Eight with a 455.
Car starts better and runs fine, except under WOT. If I keep it to 1/2 pedal or less, no problem at all. If I get on it (WOT) at any RPM I hear a slight pinging. I didn't change my timing when I installed the Pertronix.
From what I read the vacuum advance should not be an issue - so my question is: do I need to change the mechanical advance springs, or just lower the initial timing? (I read that lowering initial timing should fix it, but at the expense of power and MPG)
Thanks in advance,
Karl
wolskara is offline
Old September 14th, 2010, 12:40 PM
MN71W30's Avatar
When you installed the Pertronix the timing was changed. Set the timing and you should be good to go.
MN71W30 is offline
Old September 14th, 2010, 01:19 PM
Land Yacht Captain
66ninetyeightls's Avatar
Definately need to reset the timing after installing the pertronic as mentioned by MN71W30. Likely too far advanced now that the pertronix can control the coil faster.
66ninetyeightls is offline
Old September 14th, 2010, 09:42 PM
wolskara's Avatar
Thanks guys - I backed it down and no problem. I lost a bit of off throttle response, but I can dial it in this weekend.
Karl
wolskara is offline
Redog
April 17th, 2015 01:17 AM
allyolds68
October 4th, 2014 04:58 AM
Macadoo
August 7th, 2014 10:52 PM
1BAD71455
September 25th, 2013 06:08 AM
Redog
July 15th, 2012 06:21 PM
Quick Reply: Ping under WOT
