Supreme Headers
Supreme Headers
Also, Appledorn. Before you try and start your car do you pump on the gas pedal a few times? I have a 71 Cutlass with a 350 in it. In some cases I have to press the gas pedal 10 times or more to prime the engine enough for it to start. Otherwise it'll just sit there and keep cranking. Even after it's started sometimes its still not quite getting enough fuel on its own (unless its choking itself of course) I press on the gas and let it rev for a while. As soon as she's warmed up she runs like a dream. Give her a chance...
I recently bought a set of headers for my 71 cutlass supreme. Everywhere I read for headers it said it wouldn't fit cutlass supreme models, but would fit every other oldsmobile with a 350 in it.. The manufacturers response in all cases was that the engine in a Cutlass Supreme was offset... I eventually found headers for the car, but they're supposedly custom for cutlass supreme models.. Maybe I should make a new thread for this, but hearing you say that has aroused my curiousity once more. Was wondering if anyone can verify a difference that makes the cutlass supreme "different." Heres a link to the headers I found http://www.hedman.com/products/?id=3479&rsku=9271
Either the choke is not working properly or you have a fuel drain back issue.
I wish I knew where that "offset engine in Supremes" myth came from. The ONLY offset engine in Oldsmobile chassis is the Toronado, and that's to accommodate the front wheel drive transmission and final drive.
Some engines in some chassis might have a spacer in one of the motor mounts; if that's the case, my Custom Cruiser has an "offset engine". My 73 88 had an "offset engine". My 74 Hurst has an "offset engine". You never see that "doesn't fit due to offset engine" in those applications.
Just remember you read it here, where the Oldsgods live. Cutlass headers fit in Cutlass Supremes. The engine placement in the chassis is identical between the two cars.
How do I check for a fuel drain back issue? Its never really been an issue for concern cus I only have trouble starting up. Once started theres no issue really, its just starting it up takes a few pumps of the gas pedal before I try to crank it.
Yeah I couldn't believe it when they told me supremes are an exception. I asked for more clearification, but they wouldn't give it to me. I just bought the cutlass supreme headers so the warranty is still valid on them and they cant say its a mis-application. But even with these "special" headers I had to grind away a piece of my control arm and grind a piece of the frame away. So much for exact fit... They're small print says modifications may be needed. Is anything different in the way the engine compartment is in a supreme compared to another cutlass? Like steering boxes or anything? Thought maybe this was the issue they were referring to, that something just gets in the way with typical headers so you gotta get the "special" ones. Also, I know some chevy motors were thrown into Oldsmobile, could this also be how a myth got started? That the two engines are different?
Im not really concerned about anything. Its just been gnawing away at my curiousity.
So if you have a early 70's Cutlass with a Olds V8 it would use header made for Olds and being that the Supreme and regular Cutlass are the same under the hood so they would use the same headers.
The only difference is between the the big block and small block. Being that the big block has a taller deck height so it would need taller headers.
Thought i went crazy moving this thread
I had the same problem, i mounted a clear feulfilter and saw it drain back.
Bought me the chrome feulpump from summit and it works how it suposed to be.
It is not original, but fusick sell's only AC one's 69/ 70' 88Delta pump's.
It start's faster without pressing the gaspedal and my starter is not that hot anymore
Wish I would have just went with my gut then instead of the manufacturers. Thanks all for the info. Gonna look into my fuel issue. Probably a combo of fuel draining back and a choke adjustment.
I mounted a transparent filter for checking.
Mounted it the day i bought my olds to see how much dirt could be in the tank.
But it stay'd clean so i mounted a aluminium one so i do not see how much it is consuming
Yes, mine was leaking streight back again when i shut the engine.
Sometimes left me a drop or so but not enough to start.
I think it was the old age of the pump, and that i had it left on the shelve a while.
While making my 455 engine ready to put in.
With youre problem i would say a vacuum leak ore something, and would check the carb and sealing. and the choke to.
If someone is with you could check the filter when you start it it would flush streight in to the carb while atempting to start.
TOONLOVESCHERYL
April 7th, 2011 10:38 AM
