66 442 Throttle return spring ?????
Old April 2nd, 2010, 11:31 AM
4-Speed's Avatar
Anyone have an on the engine picture of the correct throttle return spring and bracket for a 66 442 4-speed car? Anyone have an extra bracket and spring for sale?
Dave
71rt4spd@roadrunner.com
4-Speed is offline
Old April 2nd, 2010, 11:35 AM
Run to Rund's Avatar
Qjet or Tri Carbs? post an email address and I can send a photo to you of the latter.
Run to Rund is offline
Old April 2nd, 2010, 12:00 PM
4-Speed's Avatar
Sorry, I should have mentioned 4-BBL.
thanks-
4-Speed is offline
Old April 2nd, 2010, 01:44 PM
The difference is the L shaped bracket. The top leg is longer for Tri Carbs.
Old April 2nd, 2010, 01:46 PM
4-Speed's Avatar
Is that where the spring is located? On the bell crank? If so so my spring is missing.
4-Speed is offline
Old April 2nd, 2010, 01:54 PM
"me somebody" site member
aliensatemybuick's Avatar
The return srping is part of the bellcrank, goes from a "tab" the "L" bracket" that the throttle rod connects to, to another "tab" on the part of the bellcrank assembly that bolts to the firewall. As far as I know, there is no diff between 4 bbl and trr-carb cars with respect to the spring.
You could use a secondary spring from the carb linkage to the "loop" on the intake manifold (or somewhere else) for extra caution, but it would not be "factory".
aliensatemybuick is offline
Old April 2nd, 2010, 02:16 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
Hi Dave,
The spring is in this picture, I think the one I sent to your e-mail was unreadable. Figured I'd post it here. This is from my 67 manual, 66 probably similar. I used to have a backup spring attached to the engine lift hook.
Dan
67Olds442X2 is offline
Old April 2nd, 2010, 02:27 PM
Navy P-3 FE (Ret.)
Dave,
I just went out to my Blue car and the spring is missing on mine also
I was going to pull it and try to find a duplicate. Hey but looking at the picture, the auto is the same. My Ivory car has the spring, I'll hook you up if need be.
Dan
DRXOLDS
March 2nd, 2015 07:29 AM
mv64cutlass
July 20th, 2011 06:05 AM
defiant1
May 12th, 2011 10:32 AM
Flye
August 30th, 2009 05:18 AM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 66 442 Throttle return spring ?????
