Quadrajet Vacuum Ports ??
Old June 22nd, 2009, 04:07 PM
Englishman
DAN76's Avatar
Just received my new quadrajet.
it's model 7043250 which i'm told is 1973 and from a 350 ??
Before I attempt the job, can anyone please indicate what the ports are and what goes where? I took photo's but haven't got a USB cable to hand so have numbered the ports in question on this diagram i found on google.
I'm guessing number 2 is for EG valve ??
There are also 2 ports at the rear of the carb near the top, one is bigger than the other (6 and 7, with 6 being largest).
DAN76 is offline
Old June 22nd, 2009, 05:57 PM
jensenracing77's Avatar
#1 i believe goes to the pull off right above it.
#2 PCV on valve cover
#3 probably go to the vacuum switch in the water port on the front of the intake manifold.
#4 distributor vacuum advance
#5 is a vent that you don't mess with
#6 and #7 are just for filtered air and have no vacuum on them. one will go to the choke thermostat. the other will probably go to a vacuum switch that screws into the water port on the front of the intake manifold.
i am no expert but think this is correct. i am sure that someone else will correct me if i am wrong.
jensenracing77 is offline
Old June 23rd, 2009, 12:50 AM
Englishman
DAN76's Avatar
great thanks.
not sure about number 1 as there is already a hose connecting the diaphragm to a port??
i currently have an edelbrock performer intake with edelbrock carb and when i set that up all i had was a vacuum line from the trans and one from the distributor. Where would i put the transmission?
and if the others are unused, should i simply block them off?
DAN76 is offline
Old June 23rd, 2009, 02:23 AM
the transmission line can go to any manifold port. it don't go to the carb. it can go to the carb as long as it is not ported vacuum. (the vacuum port has to be under the throttle blades)
Old June 23rd, 2009, 04:23 AM
Englishman
DAN76's Avatar
Is number 3 ported?
DAN76 is offline
Old June 23rd, 2009, 04:54 PM
Originally Posted by DAN76
Is number 3 ported?
number three is not ported vacuum. you can hook the trans to it and be good.
Old June 24th, 2009, 01:43 AM
Englishman
DAN76's Avatar
Cool, cheers.
DAN76 is offline
Tom442
June 9th, 2014 04:54 PM
stlbluesbrother
October 23rd, 2012 09:50 PM
rmoths
September 3rd, 2012 04:40 PM
rcdynamic88
October 19th, 2010 06:05 AM
blonzz
September 27th, 2004 10:54 AM
Quick Reply: Quadrajet Vacuum Ports ??
