performer 2151 intake and OEM Q-Jet | Throttle bracket question
Old April 23rd, 2019, 06:42 AM
Brians1's Avatar
Need some advice and direction.
I have the Edelbrock performer #2151 intake, and I have a OEM 4 Barrel Q-Jet for 1971. Im in process of building my first 455 (been working with CutlassEFI - Mark). I have not purchased my heads yet so while I work on saving the dough for them I was organizing my parts for the intake and carb and noticed that the factory throttle cable bracket, the carb bolt holes do not line up with those on the intake...so I can only assume I need an adapter plate ?? What else am I missing to properly mate up the Q-jet to the 2151 ?
** I will also will be ruing the OAI hood and setup so I do know I will need a drop base air cleaner, but haven't gotten that far yet - right now I want to make sure I have everything for finishing my build
Brians1 is offline
Old April 23rd, 2019, 07:52 AM
svnt442's Avatar
The 2151 should have two sets of bolt holes for the Q-Jet and aftermarket carbs. All you should need is a gasket and to bolt it down.
Use the inner bolt holes.
svnt442 is offline
Old April 23rd, 2019, 04:59 PM
Brians1's Avatar
Brians1 is offline
2oldsguy
September 6th, 2019 05:18 AM
tator62
April 7th, 2011 02:45 PM
Stevec
February 12th, 2011 07:33 PM
mike623
October 15th, 2010 12:39 PM
cutlass1972s
July 6th, 2010 06:33 PM
Quick Reply: performer 2151 intake and OEM Q-Jet | Throttle bracket question
