OAI Air Cleaner Vacuum Hose Questions
I purchased a OAI Air Cleaner for my 1968. I’m have questions on how the vacuum lines hook up and was hoping someone could help. Wee both flapper hooked up? If so, was a tee used to hook them both up? Wondering how all the vacuum lines should be correctly hooked up.
Thanks Tim
Thanks Tim
Thank you for reply and very clear picture of the page out out of the PIM. I do have a copy of the PIM but it does not clearly show how all off the vacuum lines are hooked up or if both side flappers are even hooked up. Amd if they are both hooked up what is the proper way to route them.
Tjohn8573
November 28th, 2018 02:18 PM
