piston to wall clearance
need some thought on piston to wall clearance .we've been discussing overheating at break-in on my" building a 455" thread .and im a little concerned it may be too tight clearance im using speed pro l2323f piston and i see in the machinist notes a(.0015/.002 piston to wall) does this seem too tight for a 9.6:1 street build motor ?and will things get looser after putting some time on the motor?
He told me that all my pistons fall in this range and it is a common clearance. Mark do you think this is detrimental to my build ? Should I run it at all ? From what I read .003 is more like it
.0015-.002 is typical for cast pistons. The L2323 requires .0045 or better, another reason I don’t use those.
Your machinist is an idiot. I don’t know of ANY forged piston that’s designed to run with less than .003.
At this point what would my options be ? I don’t want to continue to move forward with this if the motor is going to fail down the road . I’m ready to cut my losses now if I have to.
Back in my stock eliminator days and stock cast pistons were required,we honed the block just enough to get the piston in the hole.
in the years that the W30 was supposed to be "factory blueprinted" Olds used A pistons with a D bore for 0.0015" more clearance. I found out in the 1970s that TRW pistons would scuff in the bores at the TRW specified clearance, or even a little more like .0035" at the bottom of the skirt, and that .0045" or more was needed, as cutlass efi just said.
The Speed Pro catalog I have at the shop says .0025" I looked in another old TRW cat this evening and it says .003. Although it does not state that in the catalog the specs are usually the minimum clearance. Depending on the application you may want more. In your case i would be happy with .003 to .0035
As far as finding another shop that might be taking it too far. As long as you feel that the guy does good machine work, take it back to him and explain that you found the correct specs for the pistons and ask him to take a little bit more out of the block. If it was me that made the mistake I would certainly not charge you. To be honest with you if the pistons were new the clearance should have been on the label on the box. If you still have the box you may even want to double check to be sure that Sealed Power hasnt changed them. It wont be the first time
Also, have you actually measured the clearance ? He might have put the wrong number on the build sheet out of habit. It is your responsibility to check everything if you are assembling the engine.
In reality it's the engine assembler who is responsible for double check. If you're building your own engine and can't verify,you're out of your league. I do not mean to be critical of anybody but it's the truth.
I ran factory cast flat top pistons at .0055 well into the 6300 rpm range in my small block. It was fun and games until the skirts fell off. It didn't make any noise but I found out 3 of the skirts fell off because when I went to drain my oil it was not draining LOL this was after 2 season of racing too. those speed pro forged pistons really need .005 . I ran .005 in my last sbo with the speedpros.
x3 on the checking the machine shops work and knowing what your engine needs. Even some cheap bore gauges and mic sets will get you within a half thou +/- enough to make sure the machine shop did their work correctly or atleast in the ball park.
In my opinion take it all apart check whats already there and check it. I have had machine shops try to give me the run around and try to blame me . Then I tell them well...… lets measure it right now so I can see your claims are correct. Its that very reason I threw a crankshaft through that particular machine shops shop truck. I even left the call tag on it. I never heard from them
Ok so . . . . . I had my warehouse pull a set of pistons off the shelf and take a picture of the label.
This is why you have to double check everything !!!!!!!!! Take a look at the clearance. Maybe the machine shop wasn't so much of an idiot after all ???
Personally I would have to call Sealed Power and check to be certain.
Near 20 years ago I used the same pistons and told machinist that I always used, I'd like 0.0045 clearance. When I picked up the block he sarcastically said," you got your half." He was a good machinist, deceased now. I'd known him over 50 years. The engine is still in one of my cars, no problems.
Speedpro decided China was too expensive, India is known for it's world class manufacturing. FM needs to correct this, specs are way too tight. Of course they are an ancient design anyways and they obviously don't give a dam.
I thought the "F" in the L2323F meant they were forged pistons and forged pistons need more clearance. Either way, .001" clearance is not enough. A call to the manufacturer seems like a good idea. I would also look for the box (label) that the questionable pistons came in. I would think if the label was printed with the wrong minimum clearances, the "Manufacturer" owes you something more than an apology.
.......Just my two cents worth
That was my point also. You cannot depend on 40 year old specifications for modern parts even if the part numbers are the same. There are some coated performance pistons that are actually set up with almost zero clearance. The coating is designed to wear away slightly.
What a lot of people do not seem to understand is that pistons expand differently depending on not only the material or the way they are made (cast or forged) but also the design of the skirts and the entire piston. You pretty much have to depend on the manufacturer to give you guidance on the clearances. I suppose you can guess if you want to or rely on old information but no decent machinist or engine builder will do that. Personally I do not try to "remember" or memorize anything when it comes to engine specifications. I look it up every time and if I am buying new parts I use the information from the manufacturer.
Originally Posted by OLDSter Ralph;1151516[b
Calling the manufacturer would be a good idea.[/b]
You cannot simply state that .001 is not enough clearance without knowing the design parameters of the piston, period.
So ? Cast pistons are aluminum and they have always been run at very tight clearances.
Whats "very tight".
You are absolutely correct. But you also obviously do not work on any modern engines where .001 piston to wall clearance is pretty much normal. Main and rod bearing clearances less than .001 Etc Etc
No, I don't work on "modern engines" and could careless about them. The OP has an older Oldsmobile engine.
How do you know that Sealed Power has not redesigned their piston to a more modern design that will work just fine with that clearance ? Fact is none of us know. Except for the guy that actually designed the latest version of the part.
If you scroll back to post #1, you'll see that the engine is not a "modern engine". He is using some "modern parts" in an old engine. Without a doubt, things have changed. The OP was having a problem with overheating and piston clearance was something that was brought up.
Whats "very tight".
#31
Is he an experienced machinist or engineer? Cuz if he’s just a rep then he’s just reading from their own instructions, the same as everyone else. That doesn’t necessarily make it right. Just saying.
#32
there have been enough people over the years that have learned the hard way with these pistons that its pretty much common knowledge to run about 0.004 - 0.005 clearance with these pistons.
#34
I’ve have ran this engine on the street for about 300 miles now and it sounds and runs great never gets hotter than 180 . My ptw tolerances are right around .002 according my machinist .i am glad I had no issues as of yet
#35
Here is what I understand is standard BTR logic. If it touches when running you are in trouble, and if it doesn't you should be fine. This is precisely why some recommend a little more clearance then others. Besides this machining and measuring can be off so compensate with more and double check.
#36
Bores - 4.155 to 4.1555
Bottom of piston skirt - 4.153
