455 build - ClassicOldsmobile.com
455 build
Old December 10th, 2018, 10:26 AM
455 build
I have a 455 with C heads that I just picked up. It currently has an unknown cam that was referred to by the PO as an "RV cam". The block was bored to .030 over and has a set of +40.3cc soup bowl pistons. The deck is at factory height and the heads appear uncut and have a fresh valve job. It has the nodular crank that was turned .010 and the rods have been reworked. I also have an Edelbrock Torker intake for it.
It will be going into a 1972 Supreme and paired with a freshly rebuilt TH350 (all new seals, 5 intermediate clutch pack, hardened sprag, etc) and a 3.42 rear end. I want to be around 375-400HP and 500ft lbs of torque. I am thinking I would like to be around 9.75:1 (maybe close to 10:1 if it will still run on 93). I will be cc-ing the heads this week so I know EXACTLY where I am at to this point.
Here is what I am looking for suggestions on:
Piston?
Cam? (I want it to behave on the street, but have "an edge" to it)
Keep the Torker intake or go with the performer?
ajr2820 is offline
Old December 11th, 2018, 11:48 AM
Heads cc out at 82cc. I think I am going with the following piston.
http://www.vigilanteparts.com/Olds_4...is-pts537a.htm
ajr2820 is offline
Old December 11th, 2018, 01:51 PM
Originally Posted by ajr2820 View Post
I have a 455 with C heads that I just picked up. ...
Unless you are planning to bullet proof the valve train and do lots of high RPM, I'd suggest the performer. Get a matching cam that has max power through 5500 rpm and no more than a 750 or 780 CFM carb or FI if you've got the $$$$$.
sysmg is offline
Old December 11th, 2018, 04:21 PM
830 or 850 Quick Fuel carb, Performer intake and an Erson TQ40. You’ll hit all your marks with that combo.
cutlassefi is offline
Old December 25th, 2018, 04:55 AM
I went with the Wiseco Pro Tru piston +15.0cc and a set of Speedmaster H-beams. I figured getting the old rods separated from the current pistons and reworked for a floating pin...might as well just get new rods. Sent the rotating assembly out to be balanced.
ajr2820 is offline
Old January 19th, 2019, 06:57 AM
OK. Got everything balanced and ready to start assembly. So I calculated the compression at 9.87:1 and based on the TQ40 specs the dynamic compression will be 7.45:1 based on the intake hitting the seat at 72 deg ABDC. Should I advance this cam to get a bit more cylinder pressure? I will be running the car on 93. If so, where is the line where I would be flirting with detonation? This will be a street car so losing some on the high end is not a big concern.
ajr2820 is offline
Old February 9th, 2019, 06:26 AM
I'm about to start assembling this week. This is what I am working with:
455 F Block bored 0.030" over
Nodular crank
Speedway H-beam rods (stock length)
Wiseco pistons +15.0cc (0.010 below deck)
C heads- AIR bum removed,lightly ported with some bowl work
Compression ratio calculated at 9.91:1
Erson TQ40 cam (220/[email protected] 110cl)
Edelbrock Torker (may switch for a dual plane later, but am going to see what I get with this one since I have it)
Headers (still need to purchase)
Carb (undecided.I have access to quite a few through a friend and will test quite a few before I make this decision)
Will be paired with a TH350 with a 2400 stall convertor and 3.42 limited slip rear.
I hope to have it on the dyno sometime in March to try out different carbs and possibly even a dual plane if I can get my hands on one for testing purposes. Any guesses to the numbers this combo will put up?
ajr2820 is offline
agreen316
December 21st, 2013 06:27 AM
wildwillie1981
April 24th, 2013 04:19 PM
bobolds
March 26th, 2007 02:45 PM
scr boi
March 12th, 2007 04:40 PM
69 442 protour
December 9th, 2006 09:25 PM
Quick Reply: 455 build
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
