Pulley alignment - ClassicOldsmobile.com
Pulley alignment
Old October 29th, 2018, 06:36 PM
rpinnt's Avatar
Pulley alignment
I have a march performance serpentine conversion for my 455. I need to move the crank pulley out 1/8" to align everything. Can anyone recommend how to do it? I've found plenty of Chevy spacers but they are all for 3 hole pulleys.
rpinnt is online now
Old October 30th, 2018, 04:08 AM
Bee Saint Louis's Avatar
Have you tried to use a harmonic balanced remover and slowly bring it out to your desired depth?
Bee Saint Louis is offline
Old October 30th, 2018, 05:42 AM
rpinnt's Avatar
I could do that but would be concerned that the harmonic would then be able to slide back and forth a bit. I know it's only an 1/8". I see that ATI makes crank hub spacers (for everything but an Olds) that measure .093 which would probably be close enough. I'll check with them to see if any might fit or be close enough to modify. I could also get a couple more oil slingers and cut out the centers for spacers. I think that would be close as well.
Old October 30th, 2018, 08:14 AM
You could use machinery bushings behind the HB. These are found at Tractor Supply
You might need to file a keyway. Each one is .0747 thick
danktx is offline
Old October 30th, 2018, 09:38 AM
droldsmorland's Avatar
Call the March tech line and ask? At minimum get the steal mill cert spec on what material they are made out of for other applications. Then have a local machine shop make one if March doesn't make one. I know the conversion has been done before. Maybe you are simply not seeing the whole inventory on line? A simple piece for a machine shop to whittle out for you. Fairly critical area. Dont want to gnaw up the crank snout with shade tree mechanics.
droldsmorland is offline
Old October 30th, 2018, 11:10 AM
The balancer MUST be fully seated against the oil slinger and crank gear. More to the point, even if you pull it out, torquing the balancer bolt simply pushes it back in. If you use a spacer between the balancer and crank pulley, be sure you still have sufficient engagement between the pulley bore and the pilot on the balancer. This is what keeps the pulley concentric.
joe_padavano is offline
Bee Saint Louis
September 17th, 2018 03:26 AM
Fakser
May 15th, 2012 04:14 PM
djhoth
January 24th, 2012 09:33 AM
68Tom
September 16th, 2009 11:34 AM
projectheaven
January 26th, 2008 05:01 PM
Quick Reply: Pulley alignment
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
