í68 442 Tach Install - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Engine > Big Blocks
í68 442 Tach Install >
Old September 16th, 2018, 06:30 PM
teamwieland's Avatar
Just picked up an OEM tach off craigslist and am stumped on how to install it. Does the dash need to come off or do the gauges slide out the front? Looks to me like the gauge might slide out but havent figured it out and donít want to break anything. Also, any tips on wiring would be greatly appreciated.
teamwieland is offline
Old September 16th, 2018, 07:51 PM
It bolts in from the back of the dash. Best advice I can offer is to remove the front seat, put down some heavy blankets (the studs that hold the seat in place will shred your back unless you have some padding!!) and be prepared to spend some time laying on your back. You I will need an assortment of 1/4 inch sockets, universals, and extensions to get to all the small bolts that hold it in place. Once everything is loose, the gauge slide out from the front. Lastly, you need to add a wire from the tach to the negative side of the coil. Good luck. The dashboards of the 68-69 cars are a pain to service
matt69olds is offline
Old September 16th, 2018, 08:05 PM
Thanks Matt. Saw a thread where a guy slid 2 thin plastic discs in between the dash pad and the gauge pod to get it to come out so I was thinking maybe I could do it all from the front. My wife does yoga everyday, maybe I can convince her that this is just as fun!
Old September 17th, 2018, 07:29 AM
No, you didn't. That's an aftermarket Sun tach that someone mounted in a Cutlass gauge bezel. The OEM tach looks like this:
joe_padavano is offline
Old September 17th, 2018, 07:31 AM
From your second photo, it appears that whoever mounted that tach also manage to break off several of the mounting tabs on the back of the bezel.
Old September 17th, 2018, 08:03 AM
allyolds68's Avatar
A couple of thin frosting knives work as well. It's more difficult to get them out than back in.
& I agree with everything Matt said. Definitely remove the seat
allyolds68 is offline
Old September 17th, 2018, 08:57 AM
Thanks. If that picture above is the oem tach then thank goodness I didn’t get an oem one. Who the hell thought it was a good idea to put a clock in the middle of a tach!? Bezel looks ok to me but I can always use the existing one if there’s a problem. Tach looks much better in person than in the photo. I’ll yank the seat out and see what I can find. Hopefully the wires behind the blank gauge are right there waiting for an operational tach.
Old September 17th, 2018, 09:11 AM
allyolds68's Avatar
Thanks. If that picture above is the oem tach then thank goodness I didnít get an oem one. Who the hell thought it was a good idea to put a clock in the middle of a tach!? Bezel looks ok to me but I can always use the existing one if thereís a problem. Tach looks much better in person than in the photo. Iíll yank the seat out and see what I can find. Hopefully the wires behind the blank gauge are right there waiting for an operational tach.
If you don't have a tach already the tach lead likely won't be there.
Old September 17th, 2018, 09:18 AM
They are not. The only wires you'll find are the orange power wire for the clock and the grey illumination wire (also for the clock). You'll need to run the trigger wire from the coil. You'll also need to run a separate ground wire. I'm not an expert on older Sun tachs. Hopefully this isn't one of the very old ones that uses a separate trigger box.
Old September 17th, 2018, 09:22 AM
You've apparently never heard the term "Tic-Toc-Tach"...
joesw31
May 20th, 2018 01:28 PM
RAMBOW
October 27th, 2013 03:27 PM
JimpeBoy
June 26th, 2011 09:16 AM
MN71W30
June 8th, 2011 12:13 PM
ent72olds
June 11th, 2009 08:35 PM
Quick Reply: í68 442 Tach Install
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
