BIG LONG oil filter?
Old July 15th, 2018, 02:47 PM
Gascoop's Avatar
Ok, got your attention, anyone know of a longer maybe 1 qrt. oil filter for a 455? I use Napa/Wix pretty much exclusively and looked at thier 1049, 1258 but they are still pretty small. Looking at a Baldwin B9 but haven't seen one in person, I've got boocoo room so fitment is not an issue.....thanks, Dave
Gascoop is offline
Old July 15th, 2018, 05:36 PM
Any reason why the 1049 isn't big enough?
Fun71 is offline
Old July 15th, 2018, 06:54 PM
Gascoop's Avatar
nope, just asking if there was anything longer........
Gascoop is offline
Old July 15th, 2018, 07:18 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
The B9 will be similar to the 1049.
olds 307 and 403 is offline
Old July 15th, 2018, 07:36 PM
Gascoop's Avatar
ok thanks..........
Gascoop is offline
Old July 16th, 2018, 03:48 PM
Yellowstatue's Avatar
I've used a Carquest 85049 on a 350 and I think there is a longer one still used on a motor home.
Yellowstatue is offline
Old July 18th, 2018, 12:37 PM
friesjh's Avatar
The WIX 51258 is what GMC suggests for their motorhomes with the 455.
friesjh is offline
Old July 18th, 2018, 01:21 PM
Yes, but that is a short, fat filter. The 51049 is the same diameter but longer.
Fun71 is offline
Old July 18th, 2018, 03:34 PM
Gascoop's Avatar
Fun71.....yes you are correct, I've been doing some looking and found the WIX 51049 which is 5.178" long. Most of the others are 4.5" or shorter........ good info for those that have the room, the more oil and filter media the better. Thanks to all that replied.......... Dave
Gascoop is offline
Old July 20th, 2018, 05:41 AM
cutlassefi's Avatar
Ok you all know that the 1049 doesn’t have the same filter media as the 1258 right?
cutlassefi is offline
Old July 20th, 2018, 05:55 AM
What is the difference?
Old July 20th, 2018, 08:33 AM
cutlassefi's Avatar
i believe the 1258 has 10 micron paper, the 1049 is 20 I believe.
Old July 20th, 2018, 12:23 PM
I never saw that spec before, and I worked at a NAPA store back in school. Musta been buried in the back pages of the catalog.
Fun71 is offline
Old July 21st, 2018, 09:57 AM
Kada's Avatar
If you want cleaner oil, use a Filtermag.
Kada is offline
Old July 22nd, 2018, 10:34 AM
rekain's Avatar
I use a 1243 NAPA Gold filter on mine. Slightly larger than the 1049.
rekain is offline
455man
July 6th, 2013 02:14 PM
bulldog
March 6th, 2013 03:20 PM
Allan R
December 12th, 2011 11:35 AM
72 Olds Project
August 14th, 2011 06:43 PM
tim72
May 6th, 2010 10:58 AM
Quick Reply: BIG LONG oil filter?
