Go Back  ClassicOldsmobile.com > Repair & Restoration > Engine > Big Blocks
Blocking water pump to heater core >
Old July 13th, 2018, 09:13 PM
Can you block the out from the pump and rear of the intake or just run a hose between them ? Going to start a engine on a run stand Car probably won't have a heater also.
louie is offline
Old July 14th, 2018, 03:30 AM
You can do it either way.
oldcutlass is online now
Old July 14th, 2018, 05:50 AM
Factory heater delete cars simply blocked the ports. There is no need to run a hose. Consider that there is no hose going to the rear driver side anyway, so what makes the passenger side different?
joe_padavano is offline
Old July 16th, 2018, 07:08 AM
For a quick job you can just throw rubber caps on them. Every rubber cap I've used in the past few years has failed within a few months, so keep an eye on them.
Next time you have the water pump off the nipple can be tapped for a plug and you can replace the heater control valve with a plug.
oddball is online now
gbledsoe3
July 2nd, 2017 04:19 AM
rktolds
May 13th, 2014 08:43 PM
ent72olds
Vista Cruiser & Wagons
September 25th, 2010 02:07 PM
captjim
September 23rd, 2008 05:21 AM
blonzz
September 27th, 2004 10:54 AM
Quick Reply: Blocking water pump to heater core
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
