1974 455, any good?
Old June 25th, 2018, 11:43 AM
Fletchmo72's Avatar
1974 455, any good?
So I have the opportunity to pick up a 455 (unknown milage/cond.) and transmission for $150. I figure I can't go wrong at that price. I'm interested in building a 455 to replace my 350 in my '72 Cutlass.
I know the "J" heads are undesirable. But is there anything else about this motor I should be aware of, such as weak spots or other issues?
Alternatively, I could get a 1971 455 with approx. 78,000 mi for about $500. What's the better choice here??
Fletchmo72 is offline
Old June 25th, 2018, 11:49 AM
Go for the 74 455 for $150. That's an amazing price!
J heads will serve you just fine unless you want to build a motor for racing.
Olds64 is offline
Old June 25th, 2018, 02:21 PM
jcdynamic88's Avatar
like olds64 said the j headed 455 will be a big upgrade from a 350 but a ga head 455 would be better,i would buy them both.jc
jcdynamic88 is offline
Old June 25th, 2018, 06:26 PM
svnt442's Avatar
I would do the 74. Both wold be considered cores in need of a rebuild and starting cheaper and with a TH400 (most likely) just makes sense, even it's it's a long tail.
You can rebuild the heads, or for not much more money get some aluminum ones and have fun.
svnt442 is offline
Old June 25th, 2018, 06:38 PM
if the trans is a long tailshaft 400 it wont be much use to him in the cutlass
Old June 25th, 2018, 06:48 PM
svnt442's Avatar
They have been installed in A-body cars before. Besides, it's good trading fodder anyway because someone is always looking for a TH400.
svnt442 is offline
Old June 25th, 2018, 07:00 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Virgin 455s are getting harder to find. 150 is a great price. Nothing wrong with the J heads with good valves and mild clean-up porting. The pistons need to be upgraded to something else for performance. Or build the short block with flat tops and add Edelbrock heads. Easy 450 500 hp with the right cam, pistons, compression, and induction.
droldsmorland is offline
Old June 25th, 2018, 10:19 PM
Fletchmo72's Avatar
Thanks for all your comments! It seems now I can get 2 - 455's and trans for $400. Can't go wrong. Just wish I had a bigger garage!
Old June 26th, 2018, 06:11 AM
oldsmobiledave's Avatar
71 455
Buy the 1971 455 G head engine for $500.
With a new timing chain, a decent mild cam & a Performer intake it will make very good power on pump gas for a cheap overall price.
oldsmobiledave is offline
Old June 26th, 2018, 06:42 AM
Let us know which one you get. Of course a man can always use another Olds 455.
Olds64 is offline
Old June 26th, 2018, 09:35 AM
Fletchmo72's Avatar
That's way I need a bigger garage. I have hit the jackpot lately on 455's. I could have 4 complete motors right now for a grand total of $1300.
Old June 28th, 2018, 05:25 PM
Do Damage
67CSConvert455's Avatar
I got a 455 for $150 too but it came like this. Buy what you can afford and keep the extras for parts. t. Oh The carnage
Yup that’s a hole and a crack
Gouges down the side
Crank journal gouged also
It’s a F1 block though. Is it worth saving? I just wanted the C heads (small valve) and Torker that came with it.
67CSConvert455 is offline
Old June 28th, 2018, 11:18 PM
Gary M's Avatar
I have a 455 crank ( not nodular) for 75.00 and Some E big valve bare heads for 150.00 or G w small valve heads bare for 100.00 each. Plus shipping. May need rebuilding.
Gary M is offline
Jay Rod
March 20th, 2021 01:05 PM
kona-jack
August 27th, 2009 10:28 AM
BerBer5985
July 14th, 2009 10:38 AM
Charlie_brown
January 23rd, 2009 11:53 AM
72CUTTY
February 6th, 2008 11:33 AM
Quick Reply: 1974 455, any good?
