455 main capa
Old June 16th, 2018, 06:36 PM
Rosco920's Avatar
455 main caps
I seem to be in a pickle lol. I’m a novice at this so I need a little help. Long story short, I need main caps for a 455 block that I picked up.
Since I don’t have them, how much of a pain in the *** will it be to remedy this? Is it better/cheaper to find another block? Or is it cheap enough to just find some caps and have them put on?
I guess the machine shop will have to drill new holes for new cap screws? What’s the process?
Thanks for for the help.
Rosco920 is offline
Old June 16th, 2018, 07:30 PM
BillK's Avatar
It will probably be less expensive to find another block. The caps are machined to match the block at the factory and finding another set that is even close is just about impossible. You could buy aftermarket caps and have them installed but unless you are really planning to make a lot of power that is probably not economically feasible.
BillK is online now
Old June 16th, 2018, 07:31 PM
Run to Rund's Avatar
New caps from another block will fit directly except that the block and caps will have to be line-bored or honed so the holes will be perfectly lined up and round.
Run to Rund is offline
Old June 16th, 2018, 07:34 PM
Rosco920's Avatar
so I should be about find some main caps from another 455 and it should work? I seen the mains on eBay for $45 except he’s missing 2 bolts. Is it worth getting?
Rosco920 is offline
Old June 16th, 2018, 07:40 PM
BillK's Avatar
Have you actually done that yourself ? If you had you would know how difficult it is to find a set of caps from one block that will fit on another one without being a major pain in the *** . The problem is that they very very rarely line up side to side and there is really nothing you can do to correct it properly. Also getting the thrust to match is almost impossible.
He will definitely be better off finding another block. They are not that rare, at least not around here.
BillK is online now
Old June 16th, 2018, 07:41 PM
BillK's Avatar
Rosco, Ask your machine shop what he thinks about it
BillK is online now
Old June 16th, 2018, 07:52 PM
Rosco920's Avatar
Looks like I’ll be buying another fn block. I’ll look around for another one. I’ll try to see the one I got
Rosco920 is offline
Old June 17th, 2018, 07:08 AM
Yes. It is not the big deal you make it out to be. The caps from one block will bolt to another. Obviously you MUST have the block and new caps line bored fo fix any alignment problems. The factory machining tolerances are nowhere near as loose as you are implying. Frankly, a line bore is cheap insurance during a build anyway.
joe_padavano is offline
Old June 17th, 2018, 10:04 AM
cutlassefi's Avatar
yes. It is not the big deal you make it out to be. The caps from one block will bolt to another. Obviously you must have the block and new caps line bored fo fix any alignment problems. The factory machining tolerances are nowhere near as loose as you are implying. Frankly, a line bore is cheap insurance during a build anyway.
x2
cutlassefi is online now
Old June 17th, 2018, 06:20 PM
BillK's Avatar
Joe,
I have not done that many Olds engines but on Small and Big Block Chevy's and most other engines I have seen the difference from block to block is so bad that it makes it almost impossible to match caps from one block to another. The thrust is really hard to match. Obviously the vertical measurement is not an issue because you are going to grind the caps down some anyway but on the Chevy engines the side to side register is so terrible that it is very hard to get a nice clean round main bearing bore.
Maybe Olds did a better job of machine work than the rest of GM
BillK is online now
Oldzman71
December 4th, 2018 01:13 PM
DROLDS707172
December 3rd, 2018 06:08 PM
Octania
January 15th, 2015 10:01 AM
72cuttys
August 30th, 2012 09:05 AM
Quick Reply: 455 main capa
