Flow Cooler water pump?
Old June 14th, 2018, 09:13 PM
Gascoop's Avatar
Anybody use one of these FC 1775 pumps? For what it's worth and it may just pertain to race engines, Bill Travato doesn't like high flow water pumps, thinks they flow too much water. In fact he doesn't like mechanical water pumps at all, he likes electric water pumps which lead me to believe that his statements are indeed for race engines. So, anybody use the Flow Cooler or recommend any other good alum. water pump?....... thanks, Dave
Gascoop is offline
Old June 15th, 2018, 05:02 AM
cutlassefi's Avatar
Used dozens of hi flow mechanical pumps over the years, 0 issues.
cutlassefi is offline
Old June 15th, 2018, 06:00 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
The Flowkooler pump is a copy of the factory heavy duty cooling option closed impellar pump. Mine is 10 years old, basically a GMB aluminum made in Japan open impellar pump with a plate riveted on. The new ones have a CNC aluminum closed impellar and should be even better.
olds 307 and 403 is online now
Old June 15th, 2018, 06:49 AM
zekecut70's Avatar
Works well. No problems here!
zekecut70 is offline
Old June 15th, 2018, 09:10 AM
oddball's Avatar
Flowcooler changed the impeller design a few years ago. The new ones are nicer and no more clearance issues with the timing cover. The pictures on their website do represent the current model.
I confirmed that running a water pump dry will lead to seal failure and squeals. This wasn't exactly a surprise.
Treat it well and run the engine occasionally and it'll be fine.
oddball is offline
Old June 15th, 2018, 09:16 AM
Gascoop's Avatar
Those were my feelings exactly but all my experience were with small and big chevys.......... thanks you very much for your replys.
Gascoop is offline
Old June 15th, 2018, 12:24 PM
Be aware that the pump number above is for the 1971-newer vehicles that use a smaller diameter upper hose than the 1970-older engines.
Fun71 is online now
71DP
May 11th, 2019 02:12 AM
Mr Nick
May 4th, 2014 05:00 PM
wizard
June 27th, 2013 07:50 AM
J-(Chicago)
March 30th, 2013 02:54 PM
Driftr
October 11th, 2011 12:35 PM
Quick Reply: Flow Cooler water pump?
