1965 425 engine
Old May 28th, 2018, 11:32 AM
doggonn's Avatar
1965 425 engine
does anyone know who is a reliable seller where i can buy parts to rebuild my 425 engine? i know it has a 45 degree bank angle and parts are limited , need help.
doggonn is offline
Old May 28th, 2018, 12:25 PM
cutlassefi's Avatar
I can get you aftermarket rods, pistons, cam and lifters, no problem.
cutlassefi is offline
Old May 28th, 2018, 02:28 PM
doggonn's Avatar
what brand of parts are you selling
doggonn is offline
Old May 28th, 2018, 02:40 PM
cutlassefi's Avatar
Scat H-beam rods, Mahle Motorsports pistons and either Erson or Lunati cams and lifters. All brand name stuff.
Old June 28th, 2018, 09:18 PM
BZZBRand
BZZBRand's Avatar
Mondello!!!
BZZBRand is offline
Old June 28th, 2018, 10:39 PM
Gascoop's Avatar
BZZ ..... if you meen Bernard Mondello then yes he's a great source for alum. cyl. heads and accessories. If you meen Mondello in Paso Robles, Ca. then you need to do some much needed research on that shop.
Gascoop is offline
Old June 29th, 2018, 06:14 AM
BZZBRand
BZZBRand's Avatar
Interesting, I have had limited exposure to Mondello in Paso Robles but they did have what I needed, price was within reason and when I had an issue with some valve spring rates they took care of it. But will be careful moving forward. Thanks
BZZBRand is offline
1965Delta88okc
May 9th, 2019 08:43 AM
doggonn
February 5th, 2019 08:10 AM
RocketRonnie
October 20th, 2018 06:55 PM
edzolz
September 28th, 2018 05:29 AM
toronado12
February 11th, 2012 04:24 PM
Quick Reply: 1965 425 engine
