Intake Manifold Question
Old January 16th, 2018, 12:25 PM
timothypaul's Avatar
Okay - I'll admit, I am being totally lazy because I am sure I could search on the forums here and find the answer.
I have a 71 Cutlass / 455 motor - I kept the 350 frame mounts and 350 engine mounts.
I wanted to switch from an Edelbrock Performer to the Torker, but was concerned with the hood clearance. I thought because with those mounts the engine sat a bit higher, and the Torker is an inch taller than the performer manifold it may not clear the hood. A friend told me it should be fine, but thought I would check here with people that actually have experience.
Thanks...Tim
timothypaul is offline
Old January 16th, 2018, 01:55 PM
Originally Posted by timothypaul
I have a 71 Cutlass / 455 motor - I kept the 350 frame mounts and 350 engine mounts. I thought because with those mounts the engine sat a bit higher,
NOOOOOOOOOOOOO!
Once again, the crank centerline is in EXACTLY the same place so long as the rubber mounts match the frame pads.
joe_padavano is offline
Old January 16th, 2018, 03:06 PM
same but different
don71's Avatar
I have the same set up you are describing.
You'll be just fine and still have room. Stock air cleaner and a generic chrome air cleaner have both fit fine.
don71 is offline
Old January 16th, 2018, 03:19 PM
71cutlassdroptop's Avatar
I have a Port O sonic I would trade for your Performer. maybe someone here can shed some light on the Offenhauser port O sonic verses the Torker. Thanks
71cutlassdroptop is offline
Old January 16th, 2018, 05:05 PM
cutlassefi's Avatar
Thanks...Tim
What's your combination? Gear, Compression, etc.
cutlassefi is offline
Old January 28th, 2018, 09:30 AM
Sorry for the delayed reply...
It's a 70 455 10.5 compression / milled heads / Mondelloe MH-31 Cam (MW-31 0.474 0.474 308°/308° 234° 234° 113° 1400-5500)
Cliff Rugles built quadrejet / Turbo 400 / 2:73 Rear end
Old January 28th, 2018, 09:33 AM
2:73 Rear end
Strikes me that THIS is where you should be spending your money...
Old January 28th, 2018, 10:00 AM
Yea, definitely will need to be addressed at some point. I have never gotten the Performer to seal well and was going to make another attempt. Then I saw someone with a used Torker fairly priced so thought it may be fun to try it.
Old January 28th, 2018, 10:06 AM
I doubt the Torker will be a good match to that axle ratio.
Old January 28th, 2018, 02:46 PM
cutlassefi's Avatar
Torker is a bad choice. Get the Performer to seal and you'll be happier.
Old January 28th, 2018, 03:46 PM
I've deleted the off-topic posts. That was not fair to the OP and I apologize for letting it get to that point. Carry on with your thread.
Old January 30th, 2018, 08:59 AM
Macadoo's Avatar
Tim, you've got the A-team working for you in this thread. I've never gone wrong unless I don't listen to them. Just sayin....
Macadoo is offline
shamusj
December 18th, 2014 09:28 AM
svnt442
July 17th, 2011 04:43 PM
69442
December 29th, 2010 09:47 AM
silverriff
January 30th, 2010 12:35 PM
grt05
July 20th, 2009 05:00 AM
Quick Reply: Intake Manifold Question
