Which Vacuum Advance for 455? - ClassicOldsmobile.com
LinkBack Thread Tools Search this Thread
Old January 12th, 2018, 05:25 PM   #1
oldsonharmont's Avatar
I need to replace the vacuum advance on a stock points distributor on a '71 Cutlass 455. Rock Auto shows two AC Delco part numbers: D1393C (with a straight vacuum fitting), and D1394C (with a 90 degree vacuum fitting). Are the vacuum fittings the only difference here, or am I missing something else?
oldsonharmont is offline   Reply With Quote
Old January 12th, 2018, 06:10 PM   #2
72 Olds CS
RetroRanger's Avatar
i went to acdelcos site and searched those numbers.
unfortunately no info is given on either one, only applications, both were recommended for 68-72 442 BBO.
maybe one is a manual trans vs auto trans one>
info like the degrees advance and vacuum required would be nice.
RetroRanger is offline   Reply With Quote
Old January 12th, 2018, 08:02 PM   #3
stevengerard's Avatar
I've been looking into it myself. Unfortunately most new vacuum advances are made to handle many applications. I'm not sure what your "71 application needs but there are differences in the advance.
stevengerard is offline   Reply With Quote
Old January 12th, 2018, 08:22 PM   #4
woodie582's Avatar
Search “Lars grimsrud” contact him directly as he says his writings not sent by him and pulled off the internet are mangled by others. I worked through my ignition setup with his help.
woodie582 is offline   Reply With Quote
Old January 12th, 2018, 08:24 PM   #5
woodie582's Avatar
Also has a complete breakdown on vacuum advance. I can forward his info by email if anyone is interested.
Old January 12th, 2018, 10:28 PM   #6
Great tip on the timing articles by Lars Grimrud. After taking a closer look at the specs for both advance units, the vacuum advance with the 90 degree bend brings in advance at 8 - 10" Hg, which works well with a mild cam according to his articles.
Old January 13th, 2018, 03:03 AM   #7
Your vacuum advance specs requirement should be based on how much initial advance vs total mechanical and the amount of vacuum available. If your build and everything is set to stock then a stock advance will work. If you've setup your distributor for performance using the suggestions from the multitude of articles available, then it won't.
oldcutlass is online now   Reply With Quote
Old January 13th, 2018, 06:28 AM   #8
72 Olds CS
Quote:
Where did you find the spec info?
Old January 13th, 2018, 09:13 AM   #9
The article is a little dated, but we're talking about older cars anyway. The paragraph 'Starts at Hg' was helpful.
http://www.metroli.org/pdf/WHITE%20P...0Operation.pdf
Thread Thread Starter Forum Replies Last Post
90deg vacuum nipple on distro vacuum advance canister ReallyWildStuff Big Blocks 4 August 22nd, 2017 06:35 AM
Advance curve on Adjustable Vacuum Advance pcard General Questions 0 February 11th, 2013 05:09 PM
Vacuum Advance problem? Redog Electrical 27 June 21st, 2012 08:05 AM
70 455 vacuum advance stevengerard Big Blocks 2 October 30th, 2009 08:11 PM
Vacuum Advance Hose harleyrules Other 1 November 16th, 2007 05:27 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright © 2017 by Internet Brands, Inc.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
