Crank Timing Gear Key
When installing new timing chain set, is it more efficient to have the crank timing gear key removed first (as the CSM states), install the timing set then drive key back in or keep key in and tap gear in over the key?
86ChebbyWagon307
July 5th, 2011 07:09 PM
JMW803
May 13th, 2010 04:43 PM
