This donut is a real burnout
Last weekend I replaced the donut gasket between the exhaust manifold flange and exhaust pipe flange. It didn't seem to be working too well, so today I checked it out. After 7 days it had burned to a crisp! Is this normal? Anyway, the donut is now gone, replaced by a 2" ID to 2" OD adaptor pipe. It fits perfectly between the flanges and seals up tight. If anybody is having a leak you might try something like this.
This donut is a real burnout!
Did you anchor your exhaust pipe to close to the manifold? If there isn't some flex at that joint it will cause the O ring to blow out because the joint it's to ridged and the ring is the weakest point... Just a thought... Tedd
Tedd,
The burned-out donut gasket is what served as the o-ring. Is there another o-ring in the exhaust system? Anyway, it's quite possible that what I rigged up might be too rigid. I'm so sick of exhaust leaks that I'm willing to take the risk. So far it seems to be working. Thanks for your thoughts.
Craig
Craig
atkinsom
May 29th, 2013 06:39 PM
