Front Crank Seal behind the Harmonic Balancer
Old August 31st, 2017, 10:26 PM
Bryan Burch's Avatar
Replacing the HB, and fixing a leak. Without the Kent-Moore BT-6405 seal installation tool, how do you know how far to install the seal?
455, 1969 442.
As far as seals, I'm looking at National 472082. I have the 1050026 sealer, but what is the lubricant 1050169 that's called out in the 1969 repair manual?
Bryan Burch is offline
Old August 31st, 2017, 11:15 PM
I have always installed the seal so the front metal part is about flush with the timing cover.
Fun71 is offline
Old September 1st, 2017, 05:15 AM
It should actually be slightly past flush, though the reality is that this is not critical. If there is any groove on the HB at all, install a repair sleeve.
joe_padavano is online now
Old September 1st, 2017, 05:16 AM
At this point, I feel compelled to point out that with the HB off, you MIGHTASWELL pull the front cover and replace the timing chain...
Old September 1st, 2017, 08:50 AM
Yer killin' me, Smalls! But for real, I probably should. Damn I didn't want to drain the cooling system.
Old September 1st, 2017, 09:01 AM
Lol, see how small jobs just snowball...
oldcutlass is offline
Old September 1st, 2017, 09:03 AM
Wanna see me turn this into a body-off resto?
Old September 1st, 2017, 09:14 AM
I already have a date with the harmonic balancer and replacing the power steering system. Then I'll be crawling under the dash to straighten out 47 years of wiring no-no's from all the stereos and accessories that someone had wired in. Need new carpet, too. And those bumpers. Trumpets. Paint looks like it was put on with a broom. New new disc rotors/pads. Probably should flush the brake lines. Motor on the rear defroster sings a nice howl when it runs. Doors need re-aligned, then the front fenders/hood. Firewall grommets. For some reason, the car has a lean...not sure what that's about. Yeah, body off, soon enough!
Old September 1st, 2017, 10:02 AM
Its an affliction, you have the tell tale symptoms.
Old March 13th, 2018, 04:07 PM
Mustfire's Avatar
Does the seal come out and go back in without having to remove the timing cover?
Mustfire is offline
Old March 13th, 2018, 05:44 PM
Yes, in fact the Chassis Service Manual shows you exactly how to do that. Of course, there is a special Kent Moore tool to make this easier, but it can be done without that tool.
The only question you need to ask yourself is, how confident are you in the condition of the timing chain and cam gear?
Old March 14th, 2018, 11:39 AM
Mustfire's Avatar
Pretty confident. The engine has less than 1K miles on it. New H B installed when engine rebuilt. It has leaked since day one. BTW, how likely is it that the new H B's "shaft" diameter is not correct? What should it be?
Mustfire is offline
Old March 14th, 2018, 01:15 PM
Kennybill's Avatar
If the neoprene is off the the factory timing gear, plan on pulling the oil pan to clean the chunks out of the oil pump pickup screen . It's like hitting a wasp nest with a stick.
Kennybill is offline
Old March 14th, 2018, 05:36 PM
cutlassefi's Avatar
Or install the seal in a different spot😉.
cutlassefi is online now
Old March 14th, 2018, 06:04 PM
Gary M's Avatar
I bought an aftermarket HB for my last build that leaked. The builder measured the old HB and the new one was bigger by just enough to roll the seal and make it leak. He turned it down on a lathe and solved the leak. May not be your issue but easy enough to check. Good luck.
Gary M is offline
Old March 17th, 2018, 12:26 PM
Mustfire's Avatar
Do you know what the actual specified diameter of the H B is?
Mustfire is offline
Old March 17th, 2018, 04:06 PM
Gary M's Avatar
My old one is at the shop so they can compare size with what they buy. I'm off next week. Will try to get by there and measure the old one for you.
Gary M is offline
Old March 17th, 2018, 06:20 PM
Or they neglected to install the oil slinger.
Old March 18th, 2018, 09:30 AM
Mustfire's Avatar
okay, thanks!
Mustfire is offline
Old March 22nd, 2018, 12:08 PM
Gary M's Avatar
Measurements from my used balancer
You can see there is wear at the seal area so don't go with the smaller measurement.
Drawing represents balancer with main body on top, hub and then shaft at the bottom.
Gary M is offline
Old March 22nd, 2018, 04:37 PM
Yellowstatue's Avatar
There is a career for blue print drawing in your future.
Yellowstatue is offline
Old March 22nd, 2018, 04:44 PM
Gary M's Avatar
thankyouverymuch
I took a drafting class in high school. Was absent the day they covered neatness.
Gary M is offline
Old March 22nd, 2018, 10:13 PM
Junkman's Avatar
The material of the seals today isn't as robust as the original seals. I have had more than my share of seal failures after purchasing present day seals. In the end, I sourced NOS seals, installed them, and no more problems. If you still have the original seal, compare it to the replacement and decide for yourself if it is comparable. Sometimes they are, but most of the times, they are not.
Junkman is offline
Old March 23rd, 2018, 04:20 AM
Gary M's Avatar
Mine did this from day one after rebuild in 2013 and the HB was aftermarket. First they tried putting a sleeve on but it still leaked. Took off sleeve, turned down HB shaft on lathe to match old one (except wear groove) and fixed the leak. They said if the shaft is too big the seal material rolls over enough to loose effectiveness. May be a good idea to change the seal again and check diameter as well.
Gary M is offline
Old March 23rd, 2018, 05:53 AM
Mustfire's Avatar
I'm guessing this is in millimeters?
Mustfire is offline
Old March 23rd, 2018, 07:30 AM
Gary M's Avatar
Yes
50.81 MM or 2.005 inches
50.87 MM or 2.025 inches
Gary M is offline
Old March 24th, 2018, 09:44 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
That sounds like I did the paint job on that one.
olds 307 and 403 is offline
smcurro
March 16th, 2018 08:37 PM
smcurro
January 28th, 2009 09:00 AM
Gert3116
April 23rd, 2008 08:53 AM
martine
April 2nd, 2004 09:25 PM
Clint Reno
August 10th, 2003 10:03 PM
Quick Reply: Front Crank Seal behind the Harmonic Balancer
