OEM Alternator Bracket - Performer RPM Heads
Yesterday I pulled the alternator and power steering brackets off my original 455 and began mocking them up on my new engine (Pro Comp heads). I ran into the same exact thing you did. I'm going to take lots of measurements first, but it looks as simple as grinding part of the flange off the lower side of the alternator bracket.
Today I ground down off the lower piece so the bracket would fit flush against the head. Mounted power steering and alternator. The alternator pulley seems to be at a slight angle different from the power steering/water pump/crankshaft. I did not install the rear bracket that connects to the alternator bracket/intake/head. I don't think if it was installed it would make a difference in the angle I see. I'm not sure I have to worry about it either - although I'd like it to be straight.
At this point all of the pulleys align much better than they did on the engine that I'm removing.
