69 cutlass 455 swap headers
Okay so I've been told a million things and I'm looking for real world experience, I'm swapping my factory 350 th350 69 cutlass car with a 455, I will be using 350 motor mounts and I have a brand new set of hooker headers already coated for my 350 and I'm rounding up all my swap parts so when engine comes back from machine shop I can swap it in smoothely. I spoke with a gentleman whose has "built many of these cars" and he swears up and down that the small block headers will fit on the bbo, understanding I'd have to modify the exhaust to fit, before I drop $ on headers can someone verify this? Also has anyone used patriot headers they make for the 455 in this cutlass?
I have no experience with them so I'm no help there.
FYI, the "350 mounts" are irrelevant. The crank centerline is in exactly the same place either way. That has no affect on header fitment. In fact, in 1968, the "350 mounts" were the ONLY mounts for SBO and BBO.
Read this thread.
I'm using hooker 1 7/8 headers on my 455 69 Cutlass, they fit great. I had already moved the brake distribution valve on top of the framerail when I rebuilt the brake system. Other than that minor issue they fit great.
Did you have to move the brake distribution valve to fit the 455? Also did you have to change brake booster? I'm still not sure what to do for valve covers, I have roller rockers with poly locks and my car is a ac car
The HVAC box and booster clearance problems are the result of your valvetrain and have nothing to do with the 455 swap - 68/69 cars came with BBOs from the factory and cleared just fine. Unfortunately, you are on your own with the tall valvetrain. Lose the HVAC box (Vintage Air under the dash if you need to have A/C) and convert to a hydroboost or manual brakes.
I would rather modify my factory ac box then delete it or swap in another system, can't be that hard to cut both and fiberglass a small patch, the booster I've heard I can't just buy the 7" replacement dual diaphragm booster and that should work in just wondering if anyone else has had to do this, trying to order all the parts I need before I try and stuff the motor in, thanks
