Stock VS. L2323F-30 weight?
I dropped my block, crank, and pistons at the machinist today and he was concerned about the weight difference between the stock 455 pistons and the Sealed Pro L2323F 30 over pistons. He said a little balancing is no big deal but if they are a lot heavier, the plugs will get VERY expensive.
I've been looking for weight specs and can't find anything about either piston.
Anyone have experience making this swap?
Okay, so I found this over on Real Olds Power:
"stock early 400 piston and pin = 455 weight, about 865 g. iirc, pin weight is about 190g."
And:
"Speed Pro L2323F= 684g"
I would assume the 30 overs are a little heavier. And so far no listing for pin weight on the L2323F's.
And:
Hi Macadoo, been awhile.. Good to see the upgrades!
You have me curious about this. Are you talking about the Compression Ratio or the quality of the piston itself?
It's probably the worst forged aftermarket piston available for a 455 Olds. Heavy, short, and with an antique ring pack, the worst.
I haven't purchased the pistons yet (I dropped off my stock pistons and rods) but I did find a good deal on the L2323F's with Hastings molly rings.
If I go with a lighter piston then we'll need to remove material from the crank counterweights, yes?
Mark, I'm listening. What pistons would you recommend?
Hey Sean. Good to hear from you my friend!
I haven't purchased the pistons yet (I dropped off my stock pistons and rods) but I did find a good deal with Hastings molly rings.
My vote listen to Mark. Here was my philosophy build the best bottom end you can afford. I understand budgets and there are plenty of L2323's out there to say they are adequate. Price your options and make your decision. The machine work will cost basically the same no matter which piston you use. You can gain some extra power and have a more efficient motor with better pistons. L2323's put you around 9-9.5:1 with standard heads and gasket.
The budget went out the window already, lol. When I see what pistons Mark recommends, I'll adjust from there. The goal is to have the motor ready for next summer so I'm not in huge hurry, other than needing to tell the machinist what I'm getting.
The Rocket Racing .028 Cometics are on back order and not expected to be back in but I'll go as thin as I can, but that depends on the pistons. The chambers CC'd around 82 but I'm going to double check that. I'd like to get somewhere around 9.5 - 9.75:1 but that's a hard mark to hit, apparently, without decking and/or milling the heads. I don't want to get into intake fitment issues.
Mac, its been a long time. Those speed-pro pistons have been around since the 455 has been around. And thanks to technology we much more choices out there for our engines. I have used these pistons, and I didn't have any issues. Most people/ machine shops make the error of not putting enough clearances on the piston pin, and piston to wall clearance. I think knowing your performance goal would help Mark in his recommendations.
I have steel shim head gaskets if you decide to go that way.
Well fellas, I double checked my CC measurement and I think I nailed it this time. I didn't see any leaking through the valves or spark plug and zero bubbles in the alcohol. Looks like I have a whopping 83.5 CC chambers. I suppose that's due to all the polishing that was done to the chambers.
Performance goals are difficult to articulate exactly. I won't be taking it to the track, I don't think. It needs to be street friendly but at the same time I want to be able to tear up said street when the mood strikes. Honestly, one of the reasons I picked up the 455 is, well..........with the wife, and sometimes her brother, in this heavy car, I feel like I'm driving a 1975 Mustang II. If that makes any sense.
So I'm looking for a piston that will yield around a 9.5 CR with minimal decking and an 83.5 CC compression chamber. Several trusted people have advised against shim gaskets. Rocket Racing does sell custom .028 gaskets but they're pricey. $105 each if memory serves. In any case, I want to stay under 10:1 CR. I'm used to using 93 octane Shell fuel (I push the advance on the small block pretty hard) but I don't want to get into boosters or constantly carrying acetone in the trunk.
The 455 will give that torque you need! I have never had a shim head gasket fail on me in all the years that I have used them, I believe its personal preference. It sounds like you may need an engine built more for torque, maybe equivalent to towing. I'm sure Mark can get you the right camshaft for your needs.
Good luck with your build.
So, it looks like a CR point drop for every CC increase in chamber size (probably not that simple, but a starting point), I might be looking at a 9.6:1 CR with these pistons and no significant head milling? Am I on the right track?
Keep in mind cam profile and overlap also have an influence here not just CR. It sounds like your are sorting it out to get all of your components to work together. Waiting to see where you end up.
My cam is a donor from CopperCutlass and he's tossing in new lifters. Much appreciated, the deeper I go the more I need donations, lol.
The specs:
512/512 224/232 duration @ 050 0n a 110 lsa. Its a howards.
Lift I understand, duration too (a little) but lobe separation I don't quite understand yet.
The specs:
For anyone following this thread, Wiseco changed their part number for these pistons from PT053H3 to PTS537A3. I called and they said the dimensions are the same but they improved the forging process (?) and include a better ring pack. The rings are file-your-own so I guess I have some work to do. Or I may look for another ring pack. My machinist said they are good pistons "for the money". The weight varied by a couple of grams from piston to piston and he said there really wasn't a good place to grind to even out the weight but he wasn't too concerned.
Because of the part # change, I might have overpaid. I found these with the upgraded # on eBay for about $80 less than what I paid:
https://www.ebay.com/i/391593224610?chn=ps&dispItem=1
For more updates on this build, check out my other thread: "Mystery 455"
For anyone following this thread, Wiseco changed their part number for these pistons from PT053H3 to PTS537A3. I called and they said the dimensions are the same but they improved the forging process (?) and include a better ring pack. The rings are file-your-own so I guess I have some work to do. Or I may look for another ring pack. My machinist said they are good pistons "for the money". The weight varied by a couple of grams from piston to piston and he said there really wasn't a good place to grind to even out the weight but he wasn't too concerned. There is plenty of room in that piston to make it right.
Oh, yeah, I get what you're saying. It was badly worded. I didn't buy my pistons outright, I got them through the machinist which is probably why I paid more than the eBay price. But the original part# was higher on-line than what he was charging me.
March 6th, 2017 05:31 AM
