oil pan gasket sealer?
Hi have a quick question. Should I use a gasket sealer on my oil pan gasket when time to reinstall oil pan gasket. If it matters on a 371 motor. Rubber ends and cork sides. Thank you
Thank you. It was helpful but I see he did the gasket on the block I will need to do it on the pan as the engine will be in the car if that is possible. What will I need to remove to get access to the oil pan to drop it.
