Where to order Braided Fuel Line
Old April 20th, 2017, 09:48 PM
AK71CutlassS's Avatar
Looking to order braided fuel line 10 inch or 12 inch long with AN-8 fittings. Not sure where to find this. I'd like to order off summit but can find where u can choose lengths and fittings
AK71CutlassS is offline
Old April 21st, 2017, 04:24 AM
Summit has what your looking for:
https://www.summitracing.com/search/...%20fuel%20line
https://www.summitracing.com/search/...ose%20fittings
oldcutlass is online now
Old April 21st, 2017, 05:06 AM
Don't forget to check Jegs for their price. It's sometimes a few cents cheaper. Both places will price match each other though. I've gotten good service from both places.
Olds64 is offline
Old April 21st, 2017, 07:09 AM
csouth's Avatar
If you're not married to the braided lines, I'd check out the Earls hose and push lock fittings. They worked great for my setup.
csouth is offline
Old April 21st, 2017, 08:40 AM
But will they crimp fittings on for my specific length and size fittings ??
Old April 21st, 2017, 08:42 AM
AlSo what's a good routing setup. Just an online between fuel pump and carb?
Old April 21st, 2017, 08:46 AM
They are not a crimp type fitting, they assemble and lock together inside the fitting collar.
Old April 21st, 2017, 08:57 AM
csouth's Avatar
You order the fitting and hose to make them yourself. Its a barb that is not coming apart. They are AN fittings on one side, hose barb on the other. When I messed on up, I had to cut it off. I actually had to heat the hose a little to soften it and use a little lube to press it on. I used Russell, not Earls. It's not braided, comes black or blue and its a neat easy assembly.
https://www.summitracing.com/oh/part...4393/overview/
https://www.summitracing.com/oh/sear...cation=oh&ar=1
csouth is offline
Old April 21st, 2017, 11:29 AM
TripDeuces's Avatar
He was looking for pre-made stuff.
TripDeuces is offline
Old April 21st, 2017, 11:42 AM
csouth's Avatar
Judging by "Oldcutlass'" reply, if I misunderstood this as being "pre-made" I'm not alone. I have in my years never seen AN hoses and fittings pre-assembled unless it was application specific. Seeing as how he didn't specify anything other than braided fuel line, its hard know where its going. This is the reason we offered solutions that allowed him to make his own. If unless its a straight to straight connection, it is always better to assemble your own so the fitting is clocked correctly.
csouth is offline
Old April 21st, 2017, 11:57 AM
Although thats not what I meant in my post, they do make premade hose assemblies and are available @ Summit.
https://www.summitracing.com/search/...%20fuel%20hose
Old April 21st, 2017, 12:10 PM
csouth's Avatar
I stand corrected, you meant otherwise...
I saw those before and he did say -8AN, those are -6AN. I still stand by my theory of making my own, but one size doesn't fit all...
csouth is offline
70sx455
January 4th, 2016 07:03 AM
72cuttys
October 14th, 2013 09:30 AM
defiant1
April 2nd, 2011 09:58 AM
davepnola
December 2nd, 2010 09:00 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: Where to order Braided Fuel Line
