Cam Selection for my 455 build. Milled and ported heads
Hey everyone. Well, I'm building a 1970 cutlass supreme. I'm essentially going for a race car that has air conditioning. I live in south Texas so i will be needing my AC.
I've got a 70-72 F block 455 bored .030 over
18cc dished forged aluminum pistons
I have a set of C casting heads that are fresh from the machine shop. I don't know much about what was done to them but it looks to me like they had some port matching on the intake side and the full smoothing porting on the exhaust side. The heads also appear to have been milled down.
I'll be running a ProComp air gap intake and going with fuel injection. Probably FiTechs 600 hp system.
I also have a pair of x and z casting exhaust manifolds.
Pretty much just need to beat the pants out of a 396 ss nova.
Any advice is appreciated and if there is any interest i can take pictures of the motor or car/project.
I think you need to know the compression ratio before you can select an appropriate camshaft.
Since the heads are off it should be easy to measure the combustion chamber volume as well as how far the pistons are below the block deck. These measurements will be crucial to calculating the CR.
I've got a 70-72 F block 455 bored .030 over 18cc dished forged aluminum pistons. Based on your first statement if they're the Speed pros then throw them in the gulf.
I'll be running a ProComp air gap intake and going with fuel injection. Probably FiTechs 600 hp system. Make sure you don't run too much camshaft with that system.
I also have a pair of x and z casting exhaust manifolds. You'd pick up about 30-40 if you went with headers.
Maybe you had better tell us about this "396 Nova" and the guy that owns it, including his age. Does he have a rep?
It's my step dad and his 1968 nova ss 396 clone. It's the High hp 396. He thinks it's close to 400hp. It's all stock solid lifter motor with High flow stock manifolds. He has EFI. 4 speed Muncie M22. 373 10 bolt open differential.
My step dad is 53 I think. His car is basically a garage ornament. Also he missed 3 gear last time he got on it. I wouldn't exactly say he has a rep lol.
I'm 31 if it matters. I daily drive a hemi police package charger. It gets 26 mpg if you drive it like a normal human.
But I would just play with him rather than running him. Its easier and cheaper. A race from a dead stop, to 30 or 60 can be quiet enjoyable and over in seconds. If you have 3 or 5 car lengths on him when you get out of it...He may come flying by but the race is over, and he knows you had him LOL
215-220 duration at .050, plus a good 3000 stall converter. 9 inch slicks about 28 inches tall and about a 4.66 gear in back should do it for southern Texas. Front suspension loose to pull the front wheels. Just no fast cornering LOL Your power will be in the 4500-5000 range tops. Play to that strength and shift.
Thanks for the input guys. It's all been helpful. I'm at work and doing what research I can without getting hassled. I discovered the xe 268 like you said. Will the custom lsa grind be a noticeable difference? The 112 versus the 110 regular grind? Is it an extra cost for a custom grind?
http://www.hotrod.com/articles/camsh...rison-testing/
Is also widely available, and even companies like Mellings have it. It is 112 and less duration than the 268 XE.
One thing you have to remember is that mean sound of race cars is overlap. That's only part of it. The bleeding off of intake and exhaust (overlap), and is really meant for higher rpms. Not if the intake valve events are on the early side. It hurts mileage and vacuum, and low end torque moving it higher in the rpms. Better to have a small cam then a big one on the street, and they can go well into the 11s in a 455. This cam is even smaller yet hits 11s in a well set up 455
What you hear with a "wild" camshaft is actually the combustion process, based on whether or not you have ample cyl pressure. Lots of overlap with no cylinder pressure will sound like your grandmas' Cutlass Ciera.
Most of the generic stuff is on the lazy side. That doesn't necessarily show up on the dyno.
Nickyloves442s
July 7th, 2015 12:19 PM
