A/C Brackets
AC brackets
Here's a few shots and I've got several more angles on my photobucket site, to see them click on the link:
http://s90.photobucket.com/albums/k257/2blu442/
These are on two different engines, but they're both 1971 455's. One with the compressor attached and one without. John
Hey John could you scan that that engine and send it to me? If nobody ties a knot in the cable and it can hold the weight it should make it here with no problem.
My '71 assembly manual shows that on a 455 you use the bolt hole farther out on the compressor end of the stamped bracket that goes from the water pump to the compressor, Otherwise the same as a 350.
AC Brackets
It's been fun collecting cars and parts, but if I ever hope to use that end bay of my garage again we need more Olds people in the Pacific Northwest! It's like treasure hunting, when you find something cool in the wrecking yard or on Craigslist there's the excitement in dragging home treasure. But I guess I got a little carried away in the last few years
Bluevista, thanks for adding about the different bolt location. I've never moved a set of brackets from one directly to the other so I didn't picked up on that. If you can figure out how to move engines through the internet I'll give you first pick from the collection
Well blue i'm sure you getting carried away has benefited plenty of folks. But i don't think those brackets are what i have. I have a pump from a chevy 305 which i'm guessing won't work. The brackets are from a friends sbo 350 but they look like these.....
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-3.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-4.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-5.jpg[/IMG]
AC Brackets
Good morning Charlie Brown. What year of olds engine did you take the brackets from, and what year of car are you putting this in? The pictures I posted are from late 1960's into maybe mid 1970's but the AC compressor in one of the photos in your link looks like the late 1970's and newer. 1976 was the last year Olds used a big block so they may not have used your style of brackets on a 455. I don't know them well enough to say they will or will not fit though. I do have that setup on a 1979 GMC 1/2 used to be diesel now Olds 350. If it would help I can take photos of that and post them this afternoon. So many of the brackets will interchange between the Oldsmobile small and big blocks it may just be a matter of putting them together correctly and holding them up to the engine to see if all the bolt holes are in the right place. John
Those are the SBO-only 307 style A/C brackets. You will need to do a little welding to get them to fit the taller deck of the 455. Specifically, the bottom holes on the bracket need to have tabs welded to them to move the holes downward. The rest of the bracket bolts to the head and the taller deck height means that the bottom of the bracket no longer reaches the bolts on the block.
Prior to going with this 455 i had a 70-73 350. I could use the pics in order to know how this is supposed to mount up. I was hoping i could find some that would just bolt up though as i have never welded b4. And what car could i pull a compressor out of or could i use the one i have lying aroung off of a sbc 305?
The SBC brackets aren't even close, since the Chevy castings are completely different from the Olds castings and the mounting bolts are in completely different places (not to mention on the other side of the engine).
Ok that makes sense. i understand the brackets for the sbc won't go on an olds but its the compressor i have that is from a sbc 305 not the brackets. And i'm possitive that the compressor above and the compressor i have require different brackets.
this is the one i have
AC Brackets
What year/model of car are you working on? You could place a parts wanted ad on this site for brackets and a compressor. But if your car is setup for the style of compressor in your photograph I'm not sure the earlier compressor could use the same hoses. You may need to find someone with 350 or 403 brackets that will work on your compressor. John
DOH! Joe just beat me to the punch-oh well this was what I was going to type:
Some of this I know for certain and some I am guessing at, but hopefully this helps.
The compressor brackets that 2blu442 took pictures of are for an ACDelco A6 A/C Compressor which was a 6 piston axial design compressor. The A6 was the standard compressor in everything made by GM from early 60s to late 70s.
The compressor that Charlie brown has is very likely a Harrison R4 compressor which is a 4 piston radial design compressor. Which lasted GM all the way through the 80's. I think it started showing up in Oldsmobiles around 75 (could be wrong, oh well).
From what I gather they mount very differently, but the brackets you currently have are probably as close as you are going to get for a starting point. I would see what holes - if any - line up and cut/drill/fabricate accordingly...
Whoa! Ok i've been bogged down with work today so i haven't been able to get to the site until now. But I greatly appreciate all the feed back. Yall must understand how hot it gets here in florida.lol. But yes i have an r4. . .I'm almost positive that it has a v-belt pulley on it. My only concern is with the brackets i have could it be mounted? Or if i go junk yarden and get ah a6 style compressor would it tie in with the a/c system in the 86 442
If anyone has a picture of these brackets from #10 could you please email them to me I'm not able to view them. I had a 455 olds that had the waterpump mounted bracket on the front and it lined up perfectly with the compressor and was shaped like a "V". I don't remember what the bracket came off of but years ago when I had that 455 I came across a picture on the internet of a BBO with that exact bracket now that I'm needing info on it I cant locate it... Someone took off with that engine & some more part that I had.
You'll probably have a better chance of a response if you create a new thread. If you think its the 307 brackets you could create a post asking if anyone would share photos of the setup. I'd try putting it in the General Discussions forum.
Hey im still trying to figure this computer out, also i found the picture of the bracket that i had now comes the task of getting it identified its the one on the upper left...
i had the ine on the left
