Windage tray studs
I think I found it. Looks like it's 587509. Also, I was told that the Ford 429 has the same or similar main cap bolts that will work. Can anyone confirm this? Does anyone know where I can find these original bolts or the Ford 429 bolts if they will work?
Are head bolts the same as main bearing cap bolts? I found a stud at AMK, but want to be sure these will work for the windage tray mounting. See the following picture. It's part number B-11052. It's 3/16" shorter for the main cap and 1/16" shorter for the windage tray mounting. Will this work?
