White smoke from exhaust - smells like fuel
#81
Drove it around for a good 30 minutes about 15 miles. No smoke. Looks like that my was problem. Time will tell as I put more miles on it. Will drain the oil over the weekend and see if its clean.
Found a bit of oil around the distributor which I think is from a bad o-ring when I pulled it out. Will try replacing the o-ring. Back of the intake around the seal was dry to touch so should be good on the seals. Thanks again for the help.
