Starting specs
Starting specs
Can anyone point me in the right direction on base timing and idle mixture settings? Having trouble getting the idle below 1300-1500.
455 with Thumpr cam, headers and qjet. Unknown HEI distributor.
Will hook vacuum gauge up tomorrow. Getting past break-in point and wanted to get it a little more dialed in.
Also, with air filter on but no lid - and then removing. I noticed idle picked up (with nothing versus air cleaner with no lid - just filter).
Turns out I had a vacuum leak at the carburetor base gasket. That cured my ails. Got idle down to 800-900 RPM. Only 7-8” of vacuum though (if gauge is correct). I’ll be scouring the pick-n-pull this weekend for a booster mounted electric vacuum pump off of late model GM Tahoe/Yukon/Truck.
Thanks for the input above.
young old car guy
June 26th, 2012 09:35 AM
84oldsDelta88
December 11th, 2009 06:19 AM
