Started w/ bare 455 block... What peices am I missing?
Old September 22nd, 2011, 02:32 PM
Ben
RAMBOW's Avatar
When I got my 455, it was already a stripped & cleaned bare block, Crank, and rods & Pistons. Missing all the little stuff- No tin & no plugs.
I expect to be getting it back from machining in the next month or three- & want to start assembling the shortblock.
What "little stuff" am i missing? I hate that i didn't get to take it apart- so i have no idea what is missing.
I know I need a oil filter adapter, timing cover, timing chain/gears, oil pump, driveshaft, pan... Just trying to figure out what else.
I ordered a freeze plug kit that comes iwth some of the galley plugs... should it come with everything i need?
What about stuff under the timing cover- Is there anything in there for the fuel pump arm to ride on, or other tin oil deflectors that i might be missing?
What about in the lifter valley? is there a small tin oil delector plate that goes over the lifters, or is that only on SBO (i've seen some pics)
Thanks-
Ben
RAMBOW is offline
Old September 22nd, 2011, 03:47 PM
citcapp's Avatar
This should help you out
http://www.mondellotwister.com/engine_assembly.gif
http://www.mondellotwister.com/engine_blueprint.html
citcapp is offline
Old September 22nd, 2011, 03:59 PM
Registered car nut
nonhog's Avatar
That helps me too. (same boat, different lake) Thanks citcapp!
nonhog is offline
Old September 22nd, 2011, 05:12 PM
1968 442 restoration
getawaycar's Avatar
J-Chicago is parting out a 455 and has everything but the block. You could probably get a deal if you bought everything else.
Chris
getawaycar is offline
Old September 22nd, 2011, 07:12 PM
dre
dre's Avatar
I've got all the pulleys if you need them and also a power steering pump/pulley. $75 for all. Let me know if interested.
dre is offline
Old September 22nd, 2011, 08:51 PM
What about stuff like the distributor, carb, intake manifold, exhaust manifolds, oil fill tube/cap, starter, pulleys, alternator, power steering pump/hoses for starters. I don't know how stripped down your engine was when it went for machining.
Allan R is offline
Old September 22nd, 2011, 09:29 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I should have anything and everything to put a 455 back together. Just let me know. All those little things will add up quick picking them out of parts catalouges.
Many thanks for the reference Getawaycar.
It's projects like this that make me feel good for being too stubborn to get rid of all this olds stuff.
J-(Chicago) is offline
Old September 23rd, 2011, 10:34 AM
I'd like to order 15 lbs of Brains, 4 extra arms, and 200 hours of patience please.....
I'd like the brains to be 'experienced', the arms from 'gorillas', and oh maybe you could find some Saints or Apostles to extract the patience....
Allan R is offline
Old September 23rd, 2011, 01:47 PM
Ben
RAMBOW's Avatar
Correct me if i'm wrong, but all my pulleys and brackets from my 330 should bolt right up to the 455?
Manifolds or headers i have not decided yet.
I have a Edelbrock 455 Torquer intake & Holley 850 ready to use.
I'll be using roller rockers so i'll need aftermarket tall valve covers, so i'll get those later.
I have a toro pan & scraper setup, but I'm thinking i'll sell it and go with a milodon 7qt deep pan
From looking at that diagram appears i'm missing:
timing cover
oil filter adapter
crank or cam "eccentric" ???
cam bolt (unless a generic can be used??)
No name in that diagram, but the narrow peice of tin over the lifters in the valley
If one of you guys with the part-out motors wants to give me a quote for those peices, i'll likely pick em up. Just shoot me a PM
Thanks!
Ben
RAMBOW is offline
Old September 23rd, 2011, 02:29 PM
timing cover
oil filter adapter
Thanks!
Ben
I have all the aforementioned parts available.
Timing cover $25
Oil filter adapter $15
Eccentric&bolt $15
Lifter tin $10
Shipping $15?
How does $75 shipped for everything sound? Let me know, and I'll box them up asap for you.
Old September 23rd, 2011, 03:58 PM
ah64pilot's Avatar
timing cover
oil filter adapter
Thanks!
Ben
If you use taller valve covers, the "over the valve cover" alternator bracket may not fit...mine didn't. What type of brackets do you have? IF you have the over the cover bracket you'll want to measure your clearance.
The cam button you can get from rocket racing or mondello and it will have a brass bushing that is better than the stock bolt.
ah64pilot is offline
Old September 23rd, 2011, 11:42 PM
Ben
RAMBOW's Avatar
I took a look, my alternator bracket is the old style that goes to the intake, and not over the valve covers... but my PS bracket does go over the cover, but i think i can trim it to clear.
I'll worry about that when i get there.
J- you've got a PM
RAMBOW is offline
Old September 24th, 2011, 06:40 PM
I threw in the oil fill tube, the balancer bolt and washer, and both oil slingers.
Old September 24th, 2011, 10:47 PM
Ben
RAMBOW's Avatar
paypal payment has been sent. Thanks again!
RAMBOW is offline
jensenracing77
November 6th, 2022 09:52 PM
TicTocTach
June 16th, 2015 04:03 PM
bobb
March 10th, 2012 03:54 PM
72 Olds Project
May 6th, 2011 04:01 AM
sx455raidercelticfan
February 18th, 2011 06:03 PM
Quick Reply: Started w/ bare 455 block... What peices am I missing?
