In search of camshaft help...
I have a Oldsmobile 496 Stroker and the camshaft that I purchased (Edelbrock 2152) it's too big as it hits the counterweights of the crankshaft, I want to use the factory rocker & pushrod setup and possibly use a flat tappet cam any suggestions? Or even if I have to upgrade to a roller cam is there a roller cams that I can use with the stock rockers. My setup is .060 bore 4.500 stroke the intake & heads have been heavily ported and Gasket matched, my heads are factory iron J heads & intake and exhaust Runners have been heavily ported 10.2 :1 compression ratio & for carburetor I have a Quadrajet 750 CFM and also an 800-cfm Quadrajet...
olds 307 and 403
October 2nd, 2017 07:36 PM
1978 Oldsmobile Omega
June 15th, 2014 07:23 PM
