Pre-formed fuel lines
When you order make sure you order the correct line for the setup on your car. The hard lines ARE different depending upon correct OEM fuel pump and carb inlet location/orientation. One Size Fits All replacement pumps don't always have the connectors in the same location and/or orientation as the OEM connectors to which the lines are configured to connect. Even when everything is correct, there is likely to be some amount of adjustment required to get everything to connect without causing binding of the threads, and subsequent leaks.
Supercars has also been real good to me in the past but lately (in the last 6 months or so) there seems to be something amiss. I don't know if there's a medical issue or what but Supercars hasn't been responding as they previously did. Does anyone have updates?
Randy C.
Randy C.
On my 455 with an edelbrock performer and a quadrajet I also used an inline tube line. What I did was on bolted the carb, attached the line most of the way, then bolt down the carb and tighten the line all the way.
mefirst72
February 10th, 2013 06:37 PM
