Olffenhauser 360 intake 455
Looking for feedback on how well these perform on a street engine/stock heads mild cam. I purchased this one for $100.00 years ago. May put it & some other left over pieces on a budget build. Thanks.
Check out my post from a few months ago, I ended up just going with a performer manifold.
https://classicoldsmobile.com/forums...8/#post1369170
These Offy 360s are the goofiest intakes ever conceived. If the concept is so great, why has no one copied it in the last half a century (and the patent expired decades ago). Dividing the intake into two single plane intakes, each feeding one bank, is stupid unless you are running a flat plane crank.
You realize that the answer will be different for each engine build, right? The cam and heads that make best power with a Performer won't be the same combo as the ones that make best power with a Torker or a Victor.
WOT would only be one testing parameter. My bet is part throttle on that would be horrible. There’s literally no runner length and proportionally a huge plenum area.
Like Joe said, if it was so good why is it still so unique?
Wow this thread went sideways.
I have known boat people that loved these on their 455 boat motors. Also knew a great mechanic kid younger than me. He had one on a stock 455. Pulled the motor from a car. Rebuilt the carb and used that intake. That car ran like a some bitch.
Hundred bucks well spent. One Hundred dollars? You can buy a window crank for that now. Maybe.
Yes, I scored a Eddy Performer used w/xtra parts/gaskets/hardware for just over $200 5 years back. It went on the present 455. Has a custom cut Clay Smith Hyd/Aluminum heads/hper pistons. Ordered roller tip rockers & they sent full rollers. Anyway the left over parts aren't selling, so its time to retro-in-de-ghetto build.
Don Roberto
January 13th, 2015 07:46 PM
