Olds 496 w/ serpentine convertion 582hp/647 trq
Installed the serpentine convertion w/ all new accessories.
Engine makes 582hp/647trq
455 stroked to 496ci
BTR offset pushrod Edelbrocks 5 axis cnc ported finished by me
CP pistons
Scat rods modded to fit the Olds crank journals
torker intake
Roller cam(Cant recall spec, I'd have to dig them out) Not very big though because I didn't want to change vavle springs every year
Est 10.4-1 compression
I make and sell the adapter plates to mount the Chevy brackets to BBO & SBO
I also make and sell the shinny thermostat housing as well.
CP pistons
torker intake
Larry's brackets are nice an this build is awesome. Flowkooler has a pump to work with these.https://flowkoolerwaterpumps.com/pro...7bab2ade&_ss=r
I really like them on my 88. There is adapter brackets to run the Sanden compressor in place of crappy R4 compressor, my thoughts down the line when I add aftermarket A/C to the 70S.
https://www.dirtydingo.com/shop/mobi...-vVa3cU.mailto
The install instructions show the breakdown and on a motor.
76olds
January 19th, 2014 04:19 PM
