Olds 455 in GMC Motorhome
Hi all.
Newbie here looking for some solid advice on building a strong low end 455 for my 8500# FWD GMC 23' motorhome.
I have a set of C heads in stock (J heads on the MH) but don't know if they'd be really suitable for and engine that lives at around 3000rpm when cruising.
TH425 has a 3.07 final drive.
Have a complete spare running 455 from a parts coach with "freshly rebuilt" heads.
Maybe all I really need is a little port work and a cam to make the stock J heads breath a bit better?
I'd hate to "waste" and original set of Toronado hi-perf C heads...
Any thoughts?
Also trying to find out what those '69 C heads flow at...
Any thoughts?
Leave it alone and just clean up the J heads.
You said it yourself, it lives at 3000 rpm and below I would think.
Theres a Motorhome guy here in central Florida that actually coverts J heads for these things.
Note: I’m doing a 422ci Stroker small block for the same application. It has Edelbrock heads, 9.0:1, multiport EFI and a roller cam. BUT the owner is taking it in a different direction. It’ll be more efficient than ANY 455 yet provide similar tq.
If you could figure out how to incorporate true dual exhaust with performance mufflers it should give you a nice pop in acceleration. Single exhaust is a killer on big blocks.
If your feeling the need for speed the video below should get your juices flowing.
The number of pipes is irrelevant. It's the cross sectional area and equivalent flow rate that matters. A single 3.5" pipe has as much cross sectional area as a pair of 2.5" pipes, and frankly, probably flows slightly better because there's less surface area for the same volume and thus less boundary layer drag inside the single larger pipe.
Another possibility is enlarging the single exhaust. For example, combining 2 1/2" exhausts from both banks into a single 3 1/2" has lower back pressure than two 2 1/2" all the way back.
Hi Joe;
A common upgrade is headers and 3" exhaust all the way back from the Y...the pipe goes through the passenger side of the frame crossmembers...lots of folks put some kind of torquer cam in it.
Kinda figured the C Head would be too much for the application, but they were perfect and came with manifolds from the Toro so I couldn't NOT buy them
Hi all.
Any thoughts?
Any thoughts?
https://classicoldsmobile.com/forums/big-blocks-2/motorhome-head-cam-advice-146403/
Hi Joe;
My cam guy suggested his rv cam:
- Advertised Duration :264
- Duration at .050 : 214
- Lobe Center : 110
- 1.6 .480
9:1 compression
ported c heads
Headers and 3" exhaust
air gap manifold and efi (raised floor)
I wondering if that's much of an improvement on an early GMC 455. I'm coming up with 2 ratings for the 455 GMC, 1973 and 1976s with nothing in between.
1973 GMC 455 = 265 HP @ 4300 375 LB FT @ 2800
1976 GMC 455 = 215 HP @ 3600 370 LB FT @ 2400
Not sure for 1974 but 1973s ratings are 350 HP by old school method (gross). Plenty powerful, adding the performer as CutlassEFI suggested and true dual exhaust or equivalent maybe your looking at 300 HP and 400 LB FT net.
And then you get to worry about front brakes and front wheel bearings.
I'm told folks swap the Olds engines for 500 Cadillacs; more torque and the lack of RPM isn't a handicap.
A switch-pitch TH425 might also be an advantage.
There's various ratios available for the converter-to-transmission sprocket-and-chain system, too.
Mine came with C heads. I pulled them out and put in a new engine with rebuilt Ka heads which are same spec as C heads. It ran great and got 10-12mpg while towing in ideal conditions and around town with a lot of stop and go and hills 6-7mpg.
till i had a problem with the roller tip rocker arms I installed on the Ka heads.
i had the engine rebuilt and had a new Crank installed along with Aluminum heads and new cam reused the block, pistons and rocker tips. Upgraded to new rocker arms studs.
now I get 9- 11mpg mixed around town and highway driving. It also feels more powerful and has a lot of torque. I used the original concave Toronado type manifold. I have used a MSD Atomic with timing control. Ive no doubt a bigger taller manifold will Improve things but for what it is I am fine with it all fitting under my floor.
if You downgrade to the 403 you can use a Edelbrock performer and get away with upgrading the manifold but you looks Cubic inches.
Those were mega cool. I wonder as to how many are still left. The one in the following video could use a set of radial tires.
They should have been standard, by the time this vehicle went into production:
