oil on top of pistons after rebuild
Old July 22nd, 2020, 11:01 AM
  #41
oldaman's Avatar
thanks for the post , all machine work was done the right way , i assembled the engine and checked everything before it was put together have installed factory valley pan hope to fire it up tonight will post results
oldaman is offline
Old July 24th, 2020, 06:04 AM
  #42
oldaman's Avatar
ran engine last night no improvement , have no idea what to try next ?.
oldaman is offline
Old July 24th, 2020, 07:51 AM
  #43
BillK's Avatar
Well that stinks. I think you are missing something simple. Do you you know anyone at a decent auto repair shop ? Most of them now days have a smoke machine for checking for fuel system evap leaks etc. I know some guys have found some crazy issues with one of those machines.
BillK is offline
Old July 24th, 2020, 08:11 AM
  #44
Duh
Duh's Avatar
Are you sure you are actually seeing oil? Dirty fuel can look the same.
Duh is offline
Old July 24th, 2020, 09:28 AM
  #45
Achcoastal's Avatar
if you look at the pictures of my old gaskets above, it appears most of my oil was sucked out through the exhaust crossover. It appears that the bottom of the gaskets were compromised at the crossover and at a couple cylinder intakes allowing oil from the lifter valley to escape. Maybe try blocking exhaust crossover ports? I was losing so much oil I would only drive it around town or no more than fifty miles. Good luck,
Achcoastal is offline
Old July 24th, 2020, 11:56 AM
  #46
72Cutlass S
gs72's Avatar
You did verify that you don't have a vacuum building in the crankcase with both valve cover breather holes plugged right? I looked back though all the post and didn't see that.
gs72 is online now
Old July 24th, 2020, 11:58 AM
  #47
72Cutlass S
gs72's Avatar
Another thought. If it is a auto trans car you could be pulling trans fluid from a ruptured modulator diaphragm.
gs72 is online now
Old July 24th, 2020, 12:00 PM
  #48
72Cutlass S
gs72's Avatar
never mind on the modulator, just saw you have it on a test stand.
gs72 is online now
Old July 31st, 2020, 05:51 AM
  #49
oldaman's Avatar
thanks to all who have replied with suggestions , no problem with engine breathers, no oil in pcv hose . am 100% sure it is oil , not gas . have given up on it for awhile . will post any new developments .
oldaman is offline
Old August 2nd, 2020, 10:27 AM
  #50
Schurkey's Avatar
Have you verified the oil drainback holes on both ends of both cylinder heads?
Really, the holes at the rear of the heads are the important ones.
Olds heads have a goofy, double-drilled hole--the hole has a "bend" in the middle The upper drilling intersects the lower drilling; and the holes are not overly-large to begin with. Excess oil from crappy lifters could overwhelm the drainback holes. The valve guides would end up flooded in oil. I reworked the drainback holes on my "C" heads using a larger drill bit, careful to not drill too deeply from the top or from the bottom.
As said in an earlier post, the crappy lifters could be a root-cause; if they're supplying excess oil to the valve train, you'll want to eliminate the source of the oil flooding, not "only" enlarge the drainback.
Schurkey is offline
Old August 5th, 2020, 07:18 AM
  #51
oldaman's Avatar
drain holes are good have changed lifters from ht 951 to a set from lunati , also switched to restricted push rods. have changed intake gaskets twice since then . am having intake milled down some more this week and try again .thanks for replying
oldaman is offline
Old August 24th, 2020, 05:59 AM
  #52
oldaman's Avatar
oil on pistons
another failed attempt , this time i had intake milled down 0.10 more , painted intake black along ports on both sides let dry , painted intake ports on heads red let sit until tacky . put on intake without gaskets torqued to spec, removed intake had a good pattern of red around all intake ports on manifold , not 100 percent but enough that the gaskets should have taken care of thought for sure problem solved . am at a total f#@king loss as to what is causing this , was thinking of tearing it down and having the block decked , its the only thing i did not have checked while at the machine shop . anybody have any thoughts on this , really appreciate every body who has replied to this post
oldaman is offline
Old August 24th, 2020, 09:58 AM
  #53
OLDSter Ralph's Avatar
Are the intake manifold side of the heads square to the combustion chamber side ? Are the intake side milled straight when using the dowel pins as a reference line ? Do you have clearance between the bottom ends of the intake manifold and the top of the block ? Have you tried a different pair of heads ? Hold off decking the block for now.
OLDSter Ralph is offline
Old August 24th, 2020, 12:21 PM
  #54
oldaman's Avatar
have tried different heads ,have clearance between bottom of intake and block. what do you mean by using dowel pins as ref? cannot check first question as heads are on engine
oldaman is offline
Old August 24th, 2020, 02:07 PM
  #55
If you have tried different heads and same things happen it would seem to rule out a problem with the heads. The dowel pins in the block are in a straight line, if I recall. I was guessing the intake side of the heads got machined at some time and were off. You can check perpendicularity of the intake side of the heads with the combustion chamber side.......but since you have tried different heads, it would seem to rule that out as a problem.
Have you tried a known to be good intake manifold yet ? I am trying to rule out things before you consider decking the block. It is puzzling.
Old August 24th, 2020, 04:36 PM
  #56
Achcoastal's Avatar
I feel your pain. I admit I have no idea where to go next, but will reiterate what cured my oil loss. I was losing up to a quart every 120 miles. Compression was excellent. Car ran strong with intermittent puffs of blue smoke but not a smoke show. I ended up pulling the intake and noticed the 404 type gaskets were all Pretty much compromised on the lower Edges of the gaskets. Almost like the oil was wicking up into the intake ports. I suspect maybe a higher than normal crankcase pressure? Not sure. Have a w30 PCv system with Pcv running from the manifold with two valve cover breathers. So I installed a valley pan gasket and ditched the rubber end gaskets, where they suggest a 1/4 “ bead, I used 3/8. Bead of ultra grey. I also put a bead around every port both sides of the vp gasket. Installed and let sit overnight, crossed my fingers and fired it up. That was over a month ago and after six hundred miles have not lost any oil except for the fact I keep checking it because I’m still thinking it’s going to be low today but nope. I’m not tooting my own horn, I’m just saying what worked for me. I hope you solve your issue soon. There has to be an answer. Good luck
Old August 24th, 2020, 04:50 PM
  #57
BillK's Avatar
Old,
Where exactly are you at in Michigan ? I still think it would be a good idea to find a repair shop with a smoke machine and see if they will let you use it to smoke the engine. If it is indeed the intake gaskets it should show it pretty quickly. If you tell us where you are I can reach out through some of my connections and see if I can find a smoke machine you can borrow.
BillK is offline
Old August 24th, 2020, 05:43 PM
  #58
oldaman's Avatar
Oil on top of Pistons
I tried a factory valley pan silicone both sides with same results hey Bill I live between Lansing and Flint off interstate 69 I really appreciate your help and interest in this matter
oldaman is offline
Old August 24th, 2020, 05:47 PM
  #59
oldaman's Avatar
Achcoastall thanks for the Post I did almost exactly what you described but no luck I'm glad you were able to solve your problem give me hope on solving mine
oldaman is offline
Old August 24th, 2020, 05:49 PM
  #60
oldaman's Avatar
Forgot forgot to mention my intake gaskets look like a weeping or sucking oil from the bottom also
oldaman is offline
Old August 26th, 2020, 04:21 AM
  #61
oldaman's Avatar
took engine back to machine shop see what they come up with
oldaman is offline
Old May 3rd, 2021, 11:51 AM
  #62
oldaman's Avatar
finally solved had intake milled again fourth time i think . had other work to do on car , finally got it in car and driving so far so good
oldaman is offline
Old May 4th, 2021, 05:44 AM
  #63
Achcoastal's Avatar
Awesome! I’m glad your persistence paid off. Just in time for the summer season. Happy motoring.
Old May 4th, 2021, 07:00 AM
  #64
classicmuscle442's Avatar
Just ran across this thread, tough one to figure out but you did. Best of luck.
classicmuscle442 is offline
Old May 4th, 2021, 07:21 AM
  #65
Sugar Bear's Avatar
Oldaman that is great news, please update after you run it longer. Do you know what led to the intake not fitting well?
Sugar Bear is online now
Old May 5th, 2021, 08:58 AM
  #66
oldaman's Avatar
not really must have been intake as i changed heads previously and no change . thanks for the encouraging replies
oldaman is offline
Mr Nick
April 12th, 2021 07:26 PM
beanie
June 28th, 2013 10:45 AM
1987425
August 4th, 2012 10:05 PM
jims2000lt
May 6th, 2012 08:42 PM
tjlaugh70
May 3rd, 2011 11:02 PM
Quick Reply: oil on top of pistons after rebuild
