No Fuel to the Carb!
Hi Guys,
I have a fresh rebuilt Q-jet on my new engine. When i pour gas in the vent tube the car fires up until it runs dry. I pulled the inlet hose downstream of the pump and it is squirting fuel. Seems to be past that is the problem. I really don't want to tear into the carb. Anything I'm missing?
Craig
Craig
Craig,
Try pulling the filter out of the carb and see if by chance it was installed backwards. If it is in correctly, does it have fuel on it? If so, try tapping on the carb where the needle/seat may be to see if the needle could be stuck. Or instead of tapping on the carb, get the car over to Los Angeles and maybe the earthquakes will shake it loose.
Brian
Brian
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
RAMBOW
July 30th, 2013 03:40 PM
mefirst72
February 10th, 2013 06:37 PM
1965cutlassragtop
July 15th, 2012 06:26 PM
stlbluesbrother
March 21st, 2011 03:24 PM
