Need help on cooling
Got a 71 cutlass 455. I can't keep it cool at all. My current setup includes 2 derale electric fans rated at 4k cfm with shroud, a high flow water pump and an aluminum radiator that I feel is underperforming. I'd like to upgrade to a 3 core but before I spend the big bucks I was thinking of just going back to the stock setup of clutch and fan, which to me is more reliable anyway instead of having to worry about fans and relays working and leaving me stuck.
My questions are what is a good clutch and fan to use? I'd like the fan as big as possible too. I've went from 180 thermostat to 160 thermostat and still no change. Temps still get to 215 before I panic and cut it off
455, mild cam 226/230, headers, performer intake and sniper efi. 391 gears, 2004r.
Thanks guys for any suggestions
Overheatin
Used to be a retarded timming was #1 cause
now its cheap as stamped steel impellers...th enginers knew what they were doin ...unlike most water pump rebuilders...quality somehow has come to mean good enough that someone will buy it
When th cast iron impeller on pump is replaced with a stamped steel impeller & a under 2" inlet is employed on th casting , no good cooling will be obtained...hav a selection of OEM 6 or 7 bladed , clutched fans but th heart of your coolin system is th pump
Seldom seen yet still possability is junk outa th box thermostat
Never instal one without boilin it to see if it works properly....racecars & my racewrecker employ a washer with correct size hole so engine temp is where it should b & old faithful stays in yellowstone...not under my hood
Olds engines dont live well hot.....let it set....you'll get another 60 minutes next hour...but when can u get nuther BBO ?...& walkun aint crowded....
Are the fans pulling air? I've seen them wired reversed from the factory...
A standard two row rad sounds light for the task. Shoot the rad with an infrared looking for cool spots that are blocked internally not dissipating heat.
Good idea to change the thermostat; but, remember, a properly operating thermostat only controls the minimum operating temp. Boiling it and watching it tells when it opens and if it opens completely.
Good luck!!!
Good luck!!!
Before you tear apart the cooling system I'd use THERMO-CURE to clean the cooling system. My 455 was a fresh build and the water turned black from the rust that dissolved into the water. When looking in the radiator the deposits at the end of the cooling tubes disappeared.
I've got a 455 without a shroud, seven blade fan with new clutch hub, 3 row copper radiator. It runs at the thermostat temperature in Texas in 100+ heat. That being said when I first got the engine running I tried connecting the vacuum advance to ported vacuum and the car ran at over 205 degrees. I'm running 16 deg initial with 19 deg mechanical and have the vacuum advance limited to 11 deg.
This works for me. Good luck...
Good luck!!!
Good luck!!!
Thanks for everyone's help I've got some good ideas flowing now starting with the radiator which seems to be too small for the 455... Possibly
I run a single row 1 1/4 core aluminum radiator with plastic tanks and 1818 flexalite mechanical fan with no shroud. My temps are pretty steady at 190* with a 180* thermostat. On a 100+ day it may creep a bit at idle. Again with your FI setup, double check to make sure your not running leans and that your timing map is correct before changing the cooling system.
Come to find out I only had a 1 core in it the whole time so I knew when I put this in it should do the trick.
While driving my temp is at 185 stop light to stop light. On the highway it ranges from 177-180 which is great. I'll stick with electric fans till they break and then I'll go to clutch fan and be done.
Hi flow water pump, 160 thermostat, 2 core radiator, and derale fans with shroud, 4000 cfm.
Thanks for all the help and suggestions...
I had the same set up with the dual electric fans and a dual 1” core aluminum rad. I found that after driving mine a while the temp would start to rise especially on hotter days and I couldn’t get the temp to go down till I was moving at a good speed for awhile. I went back to a mechanical flex fan and noticed prob twice the air pulling throught the rad and never again had it clime past 185 deg. BB 455 get warm especially if you run the stock intake. A dual core rad is a good thing but I’ve found that electric fans don’t work well for big blocks. Either way though if you got it working the way you want it to that’s all that matters! Nothing rolls like an olds!
labrats804
July 19th, 2007 07:16 AM
