Lifter selection for 455
I did some recent upgrades and now have problems of burning oil and losing large amounts of oil.
New changes: New cam (Flat hydraulic, mild performance), lifters (sealed Power HT951), push rods, roller tip rockers, oil restrictors (to cam bearing passage), Ford 460 neoprene rear main seal, umbrella valve seals.
After adding the new hardware, I noticed constant oil burning from both sides and losing lots of oil, noticeable from valve covers and puddled at flywheel cover. It doesn't appear to be flowing from the rear main seal. I did some reading on this site and I'm pretty certain I was getting too much oil under the valve covers. I could see oil puddled in intake valves. I've since replaced the pushrods with new restricted pushrods which made a significant difference but I still have some burning oil (much less) with oil loss.from valve covers. After several valve cover gasket changes (cork and rubber), applying both light and heavier torque to valve covers, then new valve covers..... I don't think its just bad valve cover gaskets or deformed valve covers.
I am wondering about the lifters. I have new sealed power HT951. Has anyone used these? Has anyone experienced the same issues and found that a different lifter solved the problem? What lifters are known to be good for oil flow (not too much)? Any help or suggestions would be appreciated.
I hadn't thought about that, I've replaced the intake gasket once since this problem started. Problem the same after with second intake gasket. I thought the oil under the valve cover got so high, it pooled around the top of the valves and leaked into the valve chamber. I should have mentioned the oil drain holes are clean. The oil drain hole thru block has been cut-out and widened and the gasket at the drain hole was drilled out slightly too.
That’s not your problem.
Cutlassefi - You said that's not my problem. You're saying that oil pooling under valve cover is not my problem....is that correct? By blocking drain holes and adding oil, I'll get oil on backside of valve if the valve guides are bad....is that correct? I want to make sure I'm following your point and what I should be looking for. Thanks for the advice.
No he is just being pompous.
What he is trying to to tell you about is the myth that you can pump all your oil into the valve covers. The fact is you can't. Another fact is that if the returns are plugged you can put a significant amount of oil in the vale cover. Actualy enough to get the level above the valve guide. This is if the drains were 100% clogged.
Since I'm not there first hand and you have listed more than one problem I recommend working on one at a time. You tried to stop the oil leak from your valve covers and I'm not sure that you did. With all the gasket changes and new covers you think it would have stopped. If it hasn't it's not the valve covers. I would check the back of the intake, especially the corners. If it's leaking there you need to fix it correctly by removing the intake. At that point you can check for other intake leaks.
My ultimate advice is find someone experienced that can actualy look at it with you to give advice.
Best of luck
Best of luck
Don’t know if it’s ever been the real cause. My bet is you have guide/seal problems.
